Ana içeriğe geç
Dell Vostro 1400 RAM Replacement
Neye ihtiyacın var
  1. Dell Vostro 1400 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Be sure the power is off and all cables are unplugged from the device before starting.
    • After flipping over the laptop, the battery is on the bottom side of the laptop.
    • Find the tabs on both the left and right side of the battery.
  2. Dell Vostro 1400 RAM Replacement: adım 2, 1 resimden 1.
    • Push tabs toward the outside of the laptop until they lock in place.
  3. Dell Vostro 1400 RAM Replacement: adım 3, 2 resimden 1. Dell Vostro 1400 RAM Replacement: adım 3, 2 resimden 2.
    • Push the battery forward to eject it from the laptop.
  4. Dell Vostro 1400 RAM Replacement, RAM: adım 4, 2 resimden 1. Dell Vostro 1400 RAM Replacement, RAM: adım 4, 2 resimden 2.
    • Make sure the laptop is turned off and all cables are unplugged.
    • Loosen the three 3 mm screws on the RAM cover.
    • Screws will not completely come out.
    • Lift the cover and remove it from the laptop.
  5. Dell Vostro 1400 RAM Replacement: adım 5, 2 resimden 1. Dell Vostro 1400 RAM Replacement: adım 5, 2 resimden 2.
    • Pull tabs apart on both the top and bottom of the memory card.
    • Lift memory card and remove it from the laptop.
    • Repeat the process for the second memory card.
Sonuç
Bir başkası bu kılavuzu tamamladı.
David Hogg
739 İtibar
5 adet Kılavuz yazıldı
Ekip
Texas Tech, Team S8-G2, Bennett Spring 2017 Texas Tech, Team S8-G2, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S8G2
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 428
