Ana içeriğe geç
Dell Vostro 1400 Screen Replacement
Neye ihtiyacın var
  1. Dell Vostro 1400 Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Be sure the power is off and all cables are unplugged from the device before starting.
    • After flipping over the laptop, the battery is on the bottom side of the laptop.
    • Find the tabs on both the left and right side of the battery.
  2. Dell Vostro 1400 Screen Replacement: adım 2, 1 resimden 1.
    • Push tabs toward the outside of the laptop until they lock in place.
  3. Dell Vostro 1400 Screen Replacement: adım 3, 2 resimden 1. Dell Vostro 1400 Screen Replacement: adım 3, 2 resimden 2.
    • Push the battery forward to eject it from the laptop.
  4. Dell Vostro 1400 Screen Replacement, Screen: adım 4, 1 resimden 1.
    • Please make sure your device is completely turned off and everything is unplugged from the device
    • Open the laptop.
  5. Dell Vostro 1400 Screen Replacement: adım 5, 2 resimden 1. Dell Vostro 1400 Screen Replacement: adım 5, 2 resimden 2.
    • Remove the 6 screw hole covers surrounding the screen.
    • Remove the 6 screws that were underneath the screw covers.
  6. Dell Vostro 1400 Screen Replacement: adım 6, 2 resimden 1. Dell Vostro 1400 Screen Replacement: adım 6, 2 resimden 2.
    • Carefully remove the plastic surrounding the screen by pulling off, starting at the bottom.
    • Remove the two (2.5mm x 5mm) screws at the top, by the camera.
  7. Dell Vostro 1400 Screen Replacement: adım 7, 2 resimden 1. Dell Vostro 1400 Screen Replacement: adım 7, 2 resimden 2.
    • Remove the two 5mm screws from the camera above the screen.
    • Remove the two 5mm screws from the bottom of the screen.
  8. Dell Vostro 1400 Screen Replacement: adım 8, 2 resimden 1. Dell Vostro 1400 Screen Replacement: adım 8, 2 resimden 2.
    • Carefully remove the screen from the back cover.
  9. Dell Vostro 1400 Screen Replacement: adım 9, 2 resimden 1. Dell Vostro 1400 Screen Replacement: adım 9, 2 resimden 2.
    • Lift up the black tag holding the camera and cable together.
    • Unplug the camera from the cable.
  10. Dell Vostro 1400 Screen Replacement: adım 10, 3 resimden 1. Dell Vostro 1400 Screen Replacement: adım 10, 3 resimden 2. Dell Vostro 1400 Screen Replacement: adım 10, 3 resimden 3.
    • Unplug the two cables connected to the screen.
  11. Dell Vostro 1400 Screen Replacement: adım 11, 2 resimden 1. Dell Vostro 1400 Screen Replacement: adım 11, 2 resimden 2.
    • Remove the six 3mm screws on each side of the screen.
    • Remove the railing on each side of the screen.
    • The railing will be marked "L" for left side or "R" for the right. This should assist in reassembly.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
David Hogg
739 İtibar
5 adet Kılavuz yazıldı
Ekip
Texas Tech, Team S8-G2, Bennett Spring 2017 Texas Tech, Team S8-G2, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S8G2
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 693
