Ana içeriğe geç
Dell Vostro 15 3562 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Vostro 15 3562 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the release latch to release the battery [1].
    • Remove the battery from the computer [2].
  2. Dell Vostro 15 3562 Hard Drive Replacement, Optical-Disk Drive: adım 2, 1 resimden 1.
    • Remove the M2L3 screw that secures the optical drive to the computer [1].
    • Using a plastic scribe, push the tab in the direction of the arrow indicated on the chassis. [2].
    • Slide the optical drive out of the computer [3].
  3. Dell Vostro 15 3562 Hard Drive Replacement, KeyBoard: adım 3, 1 resimden 1.
    • Using a plastic scribe, release the five tabs from the slots located above the keyboard [1].
    • Flip the keyboard on the palm rest to access the keyboard connector cable under the keyboard [2].
  4. Dell Vostro 15 3562 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Disconnect the keyboard cable from the system board.
    • Remove the keyboard from the computer.
  5. Dell Vostro 15 3562 Hard Drive Replacement, Base Cover: adım 5, 1 resimden 1.
    • Disconnect the optical drive connector and lift it to remove it from the system board [1].
    • Remove the M2L5 screws that secure the base cover [2].
  6. Dell Vostro 15 3562 Hard Drive Replacement: adım 6, 1 resimden 1.
    • Flip the computer and remove the screws (8 screws - M2.5L8; 3 screws - M2L2; 2 screws- M2L2) that secure the base cover to the computer.
  7. Dell Vostro 15 3562 Hard Drive Replacement: adım 7, 1 resimden 1.
    • Use a scribe to pry the edges of the base cover [1].
    • Lift the base cover and remove it from the computer [2].
  8. Dell Vostro 15 3562 Hard Drive Replacement, Hard Drive: adım 8, 1 resimden 1.
    • Disconnect the hard drive cable from the connector on the system board [1].
    • Remove the M2L3 screws that secure the hard drive assembly to the computer [2].
    • Lift the hard drive assembly away from the computer [3].
Sonuç
Bir başkası bu kılavuzu tamamladı.
Johnathan Hammond
44.830 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.985 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 336
