Ana içeriğe geç
Parçalar
Hiçbir parça belirtilmedi.
  1. Slide the release latch to unlock the battery [1].
    • Slide the release latch to unlock the battery [1].
    • Remove the battery from the computer [2].
  2. Remove the screw that secures the optical drive to the computer [1].
    • Remove the screw that secures the optical drive to the computer [1].
    • Using a plastic scribe push the tab to release the optical drive [2].
    • Slide the optical drive out of the computer [3].
  3. Release the keyboard by prying on the keyboard release tabs by using a scribe.
    • Release the keyboard by prying on the keyboard release tabs by using a scribe.
  4. Slide and lift the keyboard to access the keyboard connector cable under the keyboard [1,2].
    • Slide and lift the keyboard to access the keyboard connector cable under the keyboard [1,2].
  5. Disconnect the keyboard cable from the system board [1].
    • Disconnect the keyboard cable from the system board [1].
    • Lift the keyboard cable to remove it from the computer [2].
  6. Disconnect the optical drive connector and lift it to remove it from the system board [1,2]
    • Disconnect the optical drive connector and lift it to remove it from the system board [1,2]
    • Remove the screws inside the palmrest [3].
  7. Remove the screws that secure the base cover to the computer [1].
    • Remove the screws that secure the base cover to the computer [1].
    • Pry the edges of base cover and lift it to remove it from computer [2].
  8. Pull the clips securing the memory module until the memory module pops up [1].
    • Pull the clips securing the memory module until the memory module pops up [1].
    • Remove the memory module from the system board [2].
Sonuç
Johnathan Hammond
36.011 İtibar
408 adet Kılavuz yazıldı
Takım
Informative Technologies Inc. Informative Technologies Inc. üyesi
Community
15 Üyeler
930 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 2
Her zaman: 29
