Ana içeriğe geç
Dell Vostro 15 3565 Memory Module Replacement
Neye ihtiyacın var
  1. Dell Vostro 15 3565 Memory Module Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the release latch to unlock the battery [1].
    • Remove the battery from the computer [2].
  2. Dell Vostro 15 3565 Memory Module Replacement, Optical-Disk Drive: adım 2, 1 resimden 1.
    • Remove the screw that secures the optical drive to the computer [1].
    • Using a plastic scribe push the tab to release the optical drive [2].
    • Slide the optical drive out of the computer [3].
  3. Dell Vostro 15 3565 Memory Module Replacement, KeyBoard: adım 3, 1 resimden 1.
    • Release the keyboard by prying on the keyboard release tabs by using a scribe.
  4. Dell Vostro 15 3565 Memory Module Replacement: adım 4, 1 resimden 1.
    • Slide and lift the keyboard to access the keyboard connector cable under the keyboard [1,2].
  5. Dell Vostro 15 3565 Memory Module Replacement: adım 5, 1 resimden 1.
    • Disconnect the keyboard cable from the system board [1].
    • Lift the keyboard cable to remove it from the computer [2].
  6. Dell Vostro 15 3565 Memory Module Replacement, Base Cover: adım 6, 1 resimden 1.
    • Disconnect the optical drive connector and lift it to remove it from the system board [1,2]
    • Remove the screws inside the palmrest [3].
  7. Dell Vostro 15 3565 Memory Module Replacement: adım 7, 1 resimden 1.
    • Remove the screws that secure the base cover to the computer [1].
    • Pry the edges of base cover and lift it to remove it from computer [2].
  8. Dell Vostro 15 3565 Memory Module Replacement, Memory Module: adım 8, 1 resimden 1.
    • Pull the clips securing the memory module until the memory module pops up [1].
    • Remove the memory module from the system board [2].
Sonuç
Johnathan Hammond
45.237 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 120
