Ana içeriğe geç
Dell Vostro 15 Memory Module Replacement
Neye ihtiyacın var
  1. Dell Vostro 15 Memory Module Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the battery release latches until they click into place.
    • Slide the battery out of the battery bay.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Vostro 15 Memory Module Replacement, Hinge Cover: adım 2, 1 resimden 1.
    • Open the display all the way so that it rests flat on your work surface.
    • NOTICE: To avoid damage to the hinge cover, do not lift the cover on both sides simultaneously.
    • Insert a plastic scribe into the indent to lift the hinge cover on the right side.
    • Moving from right to left, ease the hinge cover up, then remove it and set it aside.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Vostro 15 Memory Module Replacement, KeyBoard: adım 3, 1 resimden 1.
    • Remove the two M2.5 x 5-mm screws at the top of the keyboard.
    • NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Exercise care when removing and handling the keyboard.
    • Lift the keyboard and hold it up and slightly forward to access to the keyboard connector.
    • Rotate the keyboard connector latch upward to release the keyboard cable.
    • Slide the keyboard cable out of the keyboard connector.
    FixBot'a Sor
    Yorum Ekle
  4. Dell Vostro 15 Memory Module Replacement, Memory Module: adım 4, 1 resimden 1.
    • Lift the memory module cover But Do Not Remove It.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the module from the connector.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Johnathan Hammond
46.149 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
2.003 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 24
Her zaman: 288
