Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Slide the battery release latches until they click into place.
Slide the battery out of the battery bay.
Open the display all the way so that it rests flat on your work surface.
Insert a plastic scribe into the indent to lift the hinge cover on the right side.
Moving from right to left, ease the hinge cover up, then remove it and set it aside.
Remove the two M2.5 x 5-mm screws at the top of the keyboard.
Lift the keyboard and hold it up and slightly forward to access to the keyboard connector.
Rotate the keyboard connector latch upward to release the keyboard cable.
Slide the keyboard cable out of the keyboard connector.
Lift the memory module cover But Do Not Remove It.
Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
Remove the module from the connector.
