Ana içeriğe geç
Dell Vostro 1500 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Vostro 1500 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Make certain the power is off.
  2. Dell Vostro 1500 Keyboard Replacement: adım 2, 1 resimden 1.
    • Press and slide the buttons inward.
  3. Dell Vostro 1500 Keyboard Replacement: adım 3, 1 resimden 1.
    • Slide the battery away from the computer.
  4. Dell Vostro 1500 Keyboard Replacement: adım 4, 1 resimden 1.
    • Remove the battery from the slot.
  5. Dell Vostro 1500 Keyboard Replacement, Keyboard: adım 5, 3 resimden 1. Dell Vostro 1500 Keyboard Replacement, Keyboard: adım 5, 3 resimden 2. Dell Vostro 1500 Keyboard Replacement, Keyboard: adım 5, 3 resimden 3.
    • Pry the top panel up from the tab in the upper right hand corner.
    • Run your finger under the panel from right to left to pop it loose.
    • You might have to tilt back the screen if you are having trouble popping it loose.
  6. Dell Vostro 1500 Keyboard Replacement: adım 6, 2 resimden 1. Dell Vostro 1500 Keyboard Replacement: adım 6, 2 resimden 2.
    • Unscrew the two Phillips head screws.
  7. Dell Vostro 1500 Keyboard Replacement: adım 7, 2 resimden 1. Dell Vostro 1500 Keyboard Replacement: adım 7, 2 resimden 2.
    • Carefully lift the keyboard away from the computer.
    • Pull the keyboard toward the screen.
    • Do not pull too hard on the keyboard as the connector could be damaged.
  8. Dell Vostro 1500 Keyboard Replacement: adım 8, 3 resimden 1. Dell Vostro 1500 Keyboard Replacement: adım 8, 3 resimden 2. Dell Vostro 1500 Keyboard Replacement: adım 8, 3 resimden 3.
    • Lift the blue plastic cover so that is at a 90 degree angle to the keyboard to remove the connection to the keyboard.
  9. Dell Vostro 1500 Keyboard Replacement: adım 9, 1 resimden 1.
    • Pull the connector toward the screen.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Daniel Roskuski
219 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-3, Catania Fall 2016 UMass Dartmouth, Team 1-3, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S1G3
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 975
