Ana içeriğe geç
Dell Vostro 1700 Memory Module Replacement
Neye ihtiyacın var
  1. Dell Vostro 1700 Memory Module Replacement, Removing the Battery: adım 1, 1 resimden 1.
    • Slide and click the battery release latches to keep them open.
    • Slide the battery out of the bay.
  2. Dell Vostro 1700 Memory Module Replacement, Removing the Hinge Cover: adım 2, 1 resimden 1.
    • Insert a plastic scribe into the indent to lift the hinge cover on the right side.
    • Ease the hinge cover up, moving from right to left, and remove it.
  3. Dell Vostro 1700 Memory Module Replacement, Removing the Keyboard: adım 3, 1 resimden 1.
    • Remove the four screws at the top of the keyboard.
    • NOTICE: The keycaps on the keyboard are fragile, easily dislodged, and timeconsuming to replace. Be careful when removing and handling the keyboard.
    • Slide the keyboard toward the back of the computer to disengage the notch on the keyboard from the tab on the base of the computer.
    • Lift and remove the keyboard.
  4. Dell Vostro 1700 Memory Module Replacement, Removing the Memory Module: adım 4, 1 resimden 1.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the memory module from the connector.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Johnathan Hammond
46.134 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
1.998 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 45
Her zaman: 360
