Ana içeriğe geç
Dell Vostro 1700 RAM Replacement
Neye ihtiyacın var
  1. Dell Vostro 1700 RAM Replacement, Keyboard: adım 1, 3 resimden 1. Dell Vostro 1700 RAM Replacement, Keyboard: adım 1, 3 resimden 2. Dell Vostro 1700 RAM Replacement, Keyboard: adım 1, 3 resimden 3.
    • Use the Plastic Opening Tools to pry off the tab located on the right side of the top face plate.
  2. Dell Vostro 1700 RAM Replacement: adım 2, 1 resimden 1.
    • Lift the plate off the laptop from right to left.
    • Pull the plate out and remove it.
  3. Dell Vostro 1700 RAM Replacement: adım 3, 2 resimden 1. Dell Vostro 1700 RAM Replacement: adım 3, 2 resimden 2.
    • Remove the four 3mm Phillips #0 screws.
  4. Dell Vostro 1700 RAM Replacement: adım 4, 2 resimden 1. Dell Vostro 1700 RAM Replacement: adım 4, 2 resimden 2.
    • Grasp the laptop with both hands as shown.
    • Push the keyboard upwards with your thumbs to disconnect it.
  5. Dell Vostro 1700 RAM Replacement: adım 5, 2 resimden 1. Dell Vostro 1700 RAM Replacement: adım 5, 2 resimden 2.
    • Lift the keyboard from the laptop and remove it.
    • Ensure the connector is fully disconnected before lifting the keyboard out.
  6. Dell Vostro 1700 RAM Replacement, RAM: adım 6, 3 resimden 1. Dell Vostro 1700 RAM Replacement, RAM: adım 6, 3 resimden 2. Dell Vostro 1700 RAM Replacement, RAM: adım 6, 3 resimden 3.
    • Dislodge the RAM from its slot.
    • Push the retaining clips outward with your fingers.
  7. Dell Vostro 1700 RAM Replacement: adım 7, 3 resimden 1. Dell Vostro 1700 RAM Replacement: adım 7, 3 resimden 2. Dell Vostro 1700 RAM Replacement: adım 7, 3 resimden 3.
    • Pull the RAM chip up and out.
  8. Dell Vostro 1700 RAM Replacement: adım 8, 3 resimden 1. Dell Vostro 1700 RAM Replacement: adım 8, 3 resimden 2. Dell Vostro 1700 RAM Replacement: adım 8, 3 resimden 3.
    • Flip the laptop so under side is facing upwards.
    • Remove the 4.5mm Phillips #1 screw from the RAM cover.
    • Lift off the cover.
  9. Dell Vostro 1700 RAM Replacement: adım 9, 2 resimden 1. Dell Vostro 1700 RAM Replacement: adım 9, 2 resimden 2.
    • Dislodge the RAM from its slot by pushing outwards on the retaining clips.
  10. Dell Vostro 1700 RAM Replacement: adım 10, 3 resimden 1. Dell Vostro 1700 RAM Replacement: adım 10, 3 resimden 2. Dell Vostro 1700 RAM Replacement: adım 10, 3 resimden 3.
    • Lift the RAM chip up and out of the slot.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nathan Valm
735 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G1, Peak Spring 2018 UMass Dartmouth, Team S3-G1, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G1
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 1,043
