Ana içeriğe geç
Dell Vostro 1710 Fan Replacement
Neye ihtiyacın var
    1. Dell Vostro 1710 Fan Replacement, Battery: adım 1, 2 resimden 1. Dell Vostro 1710 Fan Replacement, Battery: adım 1, 2 resimden 2.
      • Make certain that the power to your laptop is off.
      • Press and slide the two buttons outwards and away from the battery.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Vostro 1710 Fan Replacement: adım 2, 1 resimden 1.
      • Slide the battery away and parallel from the laptop.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Vostro 1710 Fan Replacement: adım 3, 1 resimden 1.
      • Remove the battery from the slot.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Vostro 1710 Fan Replacement, Back Panel: adım 4, 2 resimden 1. Dell Vostro 1710 Fan Replacement, Back Panel: adım 4, 2 resimden 2.
      • Unscrew the eight 6mm screws with a Philips #1 screw driver.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Vostro 1710 Fan Replacement: adım 5, 1 resimden 1.
      • Lift back cover from the groove on the left side of the cover next to the symbol.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Vostro 1710 Fan Replacement, Fan: adım 6, 2 resimden 1. Dell Vostro 1710 Fan Replacement, Fan: adım 6, 2 resimden 2.
      • Unclip the power supply by pulling the cable directly up and out of the socket.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Vostro 1710 Fan Replacement: adım 7, 2 resimden 1. Dell Vostro 1710 Fan Replacement: adım 7, 2 resimden 2.
      • Remove the two 3mm screws located around the edge of the fan with a Philips #1 screw driver.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Vostro 1710 Fan Replacement: adım 8, 2 resimden 1. Dell Vostro 1710 Fan Replacement: adım 8, 2 resimden 2.
      • Gently lift and pull to the left until the fan is free from the heatsink.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tangxiao Sun
496 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G7, Peak Spring 2018 UMass Dartmouth, Team S3-G7, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G7
3 Üyeler
72 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 31
Her zaman: 657
