Ana içeriğe geç
Giriş
The fan helps the laptop remove the heat it produces and keeps your laptop from overheating. If your computer keeps over heating you will need to replace the fan. This guide will walk you through on how to replace the fan using only a #1 Philips head screwdriver.
Parçalar
Hiçbir parça belirtilmedi.
  1. Make certain that the power to your laptop is off. Press and slide the two buttons outwards and away from the battery.
    • Make certain that the power to your laptop is off.
    • Press and slide the two buttons outwards and away from the battery.
  2. Slide the battery away and parallel from the laptop.
    • Slide the battery away and parallel from the laptop.
  3. Remove the battery from the slot.
    • Remove the battery from the slot.
  4. Unscrew the eight 6mm screws with a Philips #1 screw driver. Unscrew the eight 6mm screws with a Philips #1 screw driver.
    • Unscrew the eight 6mm screws with a Philips #1 screw driver.
  5. Lift back cover from the groove on the left side of the cover next to the symbol.
    • Lift back cover from the groove on the left side of the cover next to the symbol.
  6. Unclip the power supply by pulling the cable directly up and out of the socket. Unclip the power supply by pulling the cable directly up and out of the socket.
    • Unclip the power supply by pulling the cable directly up and out of the socket.
  7. Remove the two 3mm screws located around the edge of the fan with a Philips #1 screw driver. Remove the two 3mm screws located around the edge of the fan with a Philips #1 screw driver.
    • Remove the two 3mm screws located around the edge of the fan with a Philips #1 screw driver.
  8. Gently lift and pull to the left until the fan is free from the heatsink. Gently lift and pull to the left until the fan is free from the heatsink.
    • Gently lift and pull to the left until the fan is free from the heatsink.
Sonuç
Tangxiao Sun
425 İtibar
4 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team S3-G7, Peak Spring 2018 UMass Dartmouth, Team S3-G7, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G7
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 2
Her zaman: 104
