Ana içeriğe geç
Dell Vostro 1710 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Vostro 1710 Hard Drive Replacement, Removing the Battery: adım 1, 1 resimden 1.
    • Slide both battery latches to the open position.
    • Slide the battery out of the battery bay.
  2. Dell Vostro 1710 Hard Drive Replacement, Loosen the Screws: adım 2, 1 resimden 1.
    • Loosen the five screws that secure the hard-drive compartment cover.
    • Remove the cover and set it aside.
  3. Dell Vostro 1710 Hard Drive Replacement, Removing the Hard Drive Cable: adım 3, 1 resimden 1.
    • Remove the three screws that secure the hard drive to the computer.
    • One screw is attached to a metal tab on the metal base of the hard drive, and the other two screws are attached to the metal base.
    • Disconnect the hard drive cable connector from the motherboard.
    • Pull the mylar tab to release the hard drive.
    • Lift the hard drive and the hard drive cable out of the computer. You may find it easier to lift the hard drive starting from the side located opposite from the hard drive's connection to the hard drive cable.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Johnathan Hammond
45.237 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 639
