Ana içeriğe geç
Dell Vostro 1710 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Vostro 1710 Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Dell Vostro 1710 Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Make certain that the power to your laptop is off.
    • Press and slide the two buttons outwards and away from the battery.
  2. Dell Vostro 1710 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Slide the battery away and parallel from the laptop.
  3. Dell Vostro 1710 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Remove the battery from the slot.
  4. Dell Vostro 1710 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 1. Dell Vostro 1710 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 2.
    • Remove the following five Phillips #1 6mm screws.
  5. Dell Vostro 1710 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Lift back cover from the groove on the right side of the cover next to the symbol.
  6. Dell Vostro 1710 Hard Drive Replacement: adım 6, 2 resimden 1. Dell Vostro 1710 Hard Drive Replacement: adım 6, 2 resimden 2.
    • Pull up on the blue tab that is attached to the ribbon cable to unplug it.
  7. Dell Vostro 1710 Hard Drive Replacement: adım 7, 2 resimden 1. Dell Vostro 1710 Hard Drive Replacement: adım 7, 2 resimden 2.
    • Remove the three Philips #1 3mm screws.
  8. Dell Vostro 1710 Hard Drive Replacement: adım 8, 2 resimden 1. Dell Vostro 1710 Hard Drive Replacement: adım 8, 2 resimden 2.
    • Lift and remove the Hard Drive frame by pulling up on the blue tab.
  9. Dell Vostro 1710 Hard Drive Replacement: adım 9, 2 resimden 1. Dell Vostro 1710 Hard Drive Replacement: adım 9, 2 resimden 2.
    • Remove the two 3mm screws with a Philips #1 screwdriver from the back side of the frame to remove the Hard drive.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jeremy Campeau
347 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G7, Peak Spring 2018 UMass Dartmouth, Team S3-G7, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G7
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 925
