Ana içeriğe geç
Dell Vostro 1710 Heatsink Replacement
Neye ihtiyacın var
  1. Dell Vostro 1710 Heatsink Replacement, Battery: adım 1, 2 resimden 1. Dell Vostro 1710 Heatsink Replacement, Battery: adım 1, 2 resimden 2.
    • Make certain that the power to your laptop is off.
    • Press and slide the two buttons outwards and away from the battery.
  2. Dell Vostro 1710 Heatsink Replacement: adım 2, 1 resimden 1.
    • Slide the battery away and parallel from the laptop.
  3. Dell Vostro 1710 Heatsink Replacement: adım 3, 1 resimden 1.
    • Remove the battery from the slot.
  4. Dell Vostro 1710 Heatsink Replacement, Back Panel: adım 4, 2 resimden 1. Dell Vostro 1710 Heatsink Replacement, Back Panel: adım 4, 2 resimden 2.
    • Unscrew the eight 6mm screws with a Philips #1 screw driver.
  5. Dell Vostro 1710 Heatsink Replacement: adım 5, 1 resimden 1.
    • Lift back cover from the groove on the left side of the cover next to the symbol.
  6. Dell Vostro 1710 Heatsink Replacement, Fan: adım 6, 2 resimden 1. Dell Vostro 1710 Heatsink Replacement, Fan: adım 6, 2 resimden 2.
    • Unclip the power supply by pulling the cable directly up and out of the socket.
  7. Dell Vostro 1710 Heatsink Replacement: adım 7, 2 resimden 1. Dell Vostro 1710 Heatsink Replacement: adım 7, 2 resimden 2.
    • Remove the two 3mm screws located around the edge of the fan with a Philips #1 screw driver.
  8. Dell Vostro 1710 Heatsink Replacement: adım 8, 2 resimden 1. Dell Vostro 1710 Heatsink Replacement: adım 8, 2 resimden 2.
    • Gently lift and pull to the left until the fan is free from the heatsink.
  9. Dell Vostro 1710 Heatsink Replacement, Heatsink: adım 9, 2 resimden 1. Dell Vostro 1710 Heatsink Replacement, Heatsink: adım 9, 2 resimden 2.
    • Unscrew the four 8mm screws using a Phillips #1 screwdriver until the heatsink is free.
    • The screws do not come out, only loosen.
  10. Dell Vostro 1710 Heatsink Replacement: adım 10, 2 resimden 1. Dell Vostro 1710 Heatsink Replacement: adım 10, 2 resimden 2.
    • Lift up on the heatsink to remove it from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tangxiao Sun
496 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G7, Peak Spring 2018 UMass Dartmouth, Team S3-G7, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G7
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 302
