Ana içeriğe geç
Dell Vostro 1710 Keyboard Replacement
Neye ihtiyacın var
    1. Dell Vostro 1710 Keyboard Replacement, Battery: adım 1, 2 resimden 1. Dell Vostro 1710 Keyboard Replacement, Battery: adım 1, 2 resimden 2.
      • Make certain that the power to your laptop is off.
      • Press and slide the two buttons outwards and away from the battery.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Vostro 1710 Keyboard Replacement: adım 2, 1 resimden 1.
      • Slide the battery away and parallel from the laptop.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Vostro 1710 Keyboard Replacement: adım 3, 1 resimden 1.
      • Remove the battery from the slot.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Vostro 1710 Keyboard Replacement, Keyboard: adım 4, 3 resimden 1. Dell Vostro 1710 Keyboard Replacement, Keyboard: adım 4, 3 resimden 2. Dell Vostro 1710 Keyboard Replacement, Keyboard: adım 4, 3 resimden 3.
      • Use the plastic opening tool to loosen the plastic hinge cover that is located above the keyboard.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Vostro 1710 Keyboard Replacement: adım 5, 2 resimden 1. Dell Vostro 1710 Keyboard Replacement: adım 5, 2 resimden 2.
      • Remove plastic hinge cover by gently lifting up the cover with a plastic opening tool from one side to the other.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Vostro 1710 Keyboard Replacement: adım 6, 2 resimden 1. Dell Vostro 1710 Keyboard Replacement: adım 6, 2 resimden 2.
      • Remove the four 3mm Philips #1 head screws.
      FixBot'a Sor
      Yorum Ekle
    4. Dell Vostro 1710 Keyboard Replacement: adım 7, 2 resimden 1. Dell Vostro 1710 Keyboard Replacement: adım 7, 2 resimden 2.
      • Gently lift up the keyboard to remove.
      • Flip it over as it shown in the picture.
      FixBot'a Sor
      Yorum Ekle
    5. Dell Vostro 1710 Keyboard Replacement: adım 8, 2 resimden 1. Dell Vostro 1710 Keyboard Replacement: adım 8, 2 resimden 2.
      • Lift the black tab that the keyboard is plugged into.
      FixBot'a Sor
      Yorum Ekle
    6. Dell Vostro 1710 Keyboard Replacement: adım 9, 2 resimden 1. Dell Vostro 1710 Keyboard Replacement: adım 9, 2 resimden 2.
      • Pull directly outwards to remove the keyboard completely.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Tangxiao Sun
496 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G7, Peak Spring 2018 UMass Dartmouth, Team S3-G7, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G7
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 37
Her zaman: 1,016
