Ana içeriğe geç
Dell Vostro 1710 RAM Replacement
Neye ihtiyacın var
    1. Dell Vostro 1710 RAM Replacement, Battery: adım 1, 2 resimden 1. Dell Vostro 1710 RAM Replacement, Battery: adım 1, 2 resimden 2.
      • Make certain that the power to your laptop is off.
      • Press and slide the two buttons outwards and away from the battery.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Vostro 1710 RAM Replacement: adım 2, 1 resimden 1.
      • Slide the battery away and parallel from the laptop.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Vostro 1710 RAM Replacement: adım 3, 1 resimden 1.
      • Remove the battery from the slot.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Vostro 1710 RAM Replacement, Back Panel: adım 4, 2 resimden 1. Dell Vostro 1710 RAM Replacement, Back Panel: adım 4, 2 resimden 2.
      • Unscrew the eight 6mm screws with a Philips #1 screw driver.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Vostro 1710 RAM Replacement: adım 5, 1 resimden 1.
      • Lift back cover from the groove on the left side of the cover next to the symbol.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Vostro 1710 RAM Replacement, RAM: adım 6, 2 resimden 1. Dell Vostro 1710 RAM Replacement, RAM: adım 6, 2 resimden 2.
      • Push the metal tabs outward and away from the RAM.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Vostro 1710 RAM Replacement: adım 7, 2 resimden 1. Dell Vostro 1710 RAM Replacement: adım 7, 2 resimden 2.
      • Pull the top piece straight out of the socket.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Vostro 1710 RAM Replacement: adım 8, 2 resimden 1. Dell Vostro 1710 RAM Replacement: adım 8, 2 resimden 2.
      • Repeat the same process by pushing the bottom metal tabs outward and away from the RAM.
      FixBot'a Sor
      Yorum Ekle
    4. Dell Vostro 1710 RAM Replacement: adım 9, 2 resimden 1. Dell Vostro 1710 RAM Replacement: adım 9, 2 resimden 2.
      • Pull the bottom piece straight out of the socket.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Sarah Dulac
270 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G7, Peak Spring 2018 UMass Dartmouth, Team S3-G7, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G7
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 750
