Neye ihtiyacın var
Slide the left and the right battery release latches to the unlock position.
Press the keyboard down. Pry the keyboard with the use of a flat-head screwdriver towards the display to reveal the first keyboard retainer.
Release the latch on the system board connector, then disconnect the keyboard cable.
It is also required to loose the screw just beside the latch mentioned in this step.
Pry up the memory door near the screw hole, lift and remove it.
Gently pry the optical drive out of the computer.
Make sure you have loosen the screw beside the keyboard cable latch, mentioned in the comments of Step 8.
Remove the screws that secure the optical drive bracket.
Remove the optical drive bracket from the optical drive module.
Flip the computer around and remove the screws that secures the palm rest.
Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
Release the latch on the system board connector and then disconnect the power button cable.
Release the latch on the system board connector and then disconnect the hot key cable.
Pry up the right side of the palm rest.
There are a couple of latches on the front of the palm rest which should be released before you move on to the sides. I think one of those latches is released in the picture above. The iFixit opening tool was helpful here, and I used some of the iFixit opening picks to stop the corner latches from closing while I worked on others.
Remove the screws that secure the hinge cover.
You can skip this step, and others related to removing the display, because removing the display isn’t strictly necessary.
Con of removing the display:
o It takes time
Pros of removing the display:
o It makes it a little easier to remove the VGA card
o The computer will tip with the weight of the display when you remove other components.
Flip the computer around and remove the hinge cover from the side.
Loosen the screw that secures the low-voltage differential signaling (LVDS) cable.
Disconnect the LVDS cable from the system board.
By pulling it upwards?
Disconnect the wireless local area network (WLAN) antenna cable.
Lift the display assembly and remove it from the computer.
Remove the screw that secures the WLAN card.
Pull the WLAN card straight out of its socket and remove it.
You can skip this step, it isn’t strictly necessary.
Cons of removing the WLAN card:
o I found the screw in the last step very stubborn, worried about stripping it.
o Takes time.
Pros of removing the WLAN card:
o Might make disconnecting the system board a little easier later. I had no trouble with the WLAN card in place though.
Release the latch on the system board and then disconnect the VGA cable.
Remove the VGA board from the chassis.
If you decided to leave the display in place, you can just loosen the screw on the VGA board, and leave the board itself where it is. The board blocks access to a screw securing the system fan, but once you’ve removed the screw from the VGA board you can just push the VGA board out of the way and remove the system fan screw. Of course, this means the VGA board can move around while you’re working on the rest of the computer, but I didn’t find that was a big problem. You could temporarily reinstall the VGA board screw after you’ve removed the system fan.
Disconnect the system fan cable from the system board.
Remove the system fan from the bottom base module.
Disconnect the DC-in cable connector from the system board.
Remove the screws that secures the system board.
Disconnect the system board from the Input/Output panel.
4 farklı kişi bu kılavuzu tamamladı.
4 Yorum
Who the !&&* designs a hard drive location that requires complete disassembly of the motherboard and the laptop to replace. Horrible, horrible design.
