Ana içeriğe geç
Dell Vostro 3450 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Vostro 3450 Hard Drive Replacement, Unlocking the Battery: adım 1, 1 resimden 1.
    • Slide the left and the right battery release latches to the unlock position.
  2. Dell Vostro 3450 Hard Drive Replacement, Removing the Battery: adım 2, 1 resimden 1.
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3450 Hard Drive Replacement, Press the ExpressCard: adım 3, 1 resimden 1.
    • Press the ExpressCard to release it from the computer.
  4. Dell Vostro 3450 Hard Drive Replacement, Slide the ExpressCard: adım 4, 1 resimden 1.
    • Slide the ExpressCard out of the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  5. Dell Vostro 3450 Hard Drive Replacement, Prying the Keyboard: adım 5, 1 resimden 1.
    • Press the keyboard down. Pry the keyboard with the use of a flat-head screwdriver towards the display to reveal the first keyboard retainer.
  6. Dell Vostro 3450 Hard Drive Replacement, Prying the Keyboard retainer: adım 6, 1 resimden 1.
    • Pry up the second keyboard retainer.
  7. Dell Vostro 3450 Hard Drive Replacement, Pry up the Keyboard Retainer: adım 7, 1 resimden 1.
    • Pry up the third keyboard retainer.
  8. Dell Vostro 3450 Hard Drive Replacement, Prying the Retainer: adım 8, 1 resimden 1.
    • Pry up the fourth keyboard retainer.
  9. Dell Vostro 3450 Hard Drive Replacement, Pull up the Keyboard: adım 9, 1 resimden 1.
    • Pull up the keyboard from the palm rest.
  10. Dell Vostro 3450 Hard Drive Replacement, Release the Latch: adım 10, 1 resimden 1.
    • Release the latch on the system board connector, then disconnect the keyboard cable.
    It is also required to loose the screw just beside the latch mentioned in this step.
    fernandolordao - Yanıt
    These (and Dell’s) instructions don’t mention that you have to disconnect a second keyboard cable. It’s a 4 pin ZIF connector, you can see it in the picture above, already disconnected.
    BorpoIT - Yanıt
  11. Dell Vostro 3450 Hard Drive Replacement, Loosen the Screw: adım 11, 1 resimden 1.
    • Loosen the screw that secures the memory door.
  12. Dell Vostro 3450 Hard Drive Replacement, Removing the Memory Door: adım 12, 1 resimden 1.
    • Pry up the memory door near the screw hole, lift and remove it.
  13. Dell Vostro 3450 Hard Drive Replacement, Remove the Screw: adım 13, 1 resimden 1.
    • Remove the screw that secures the optical drive to the computer.
  14. Dell Vostro 3450 Hard Drive Replacement, Prying the Drive: adım 14, 1 resimden 1.
    • Gently pry the optical drive out of the computer.
    Make sure you have loosen the screw beside the keyboard cable latch, mentioned in the comments of Step 8.
  15. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: adım 15, 1 resimden 1.
    • Remove the screws that secure the optical drive bracket.
    You can skip this step when replacing the HDD, it isn’t necessary at all.
    BorpoIT - Yanıt
  16. Dell Vostro 3450 Hard Drive Replacement, Removing the Optical Drive: adım 16, 1 resimden 1.
    • Remove the optical drive bracket from the optical drive module.
    BorpoIT - Yanıt
  17. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: adım 17, 1 resimden 1.
    • Remove the screws in the battery compartment.
  18. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: adım 18, 1 resimden 1.
    • Remove the screws in the optical drive compartment.
  19. Dell Vostro 3450 Hard Drive Replacement, Remove the Rubber: adım 19, 1 resimden 1.
    • Remove the rubber from the bottom base on the right side.
  20. Dell Vostro 3450 Hard Drive Replacement, Remove the Rubber: adım 20, 1 resimden 1.
    • Remove the rubber from the bottom base on the left side.
  21. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: adım 21, 1 resimden 1.
    • Remove all the screws from the bottom base.
  22. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: adım 22, 1 resimden 1.
    • Flip the computer around and remove the screws that secures the palm rest.
  23. Dell Vostro 3450 Hard Drive Replacement, Release the Latches: adım 23, 1 resimden 1.
    • Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
  24. Dell Vostro 3450 Hard Drive Replacement, Release the Latch: adım 24, 1 resimden 1.
    • Release the latch on the system board connector and then disconnect the power button cable.
  25. Dell Vostro 3450 Hard Drive Replacement, Disconnecting the Key Cable: adım 25, 1 resimden 1.
    • Release the latch on the system board connector and then disconnect the hot key cable.
  26. Dell Vostro 3450 Hard Drive Replacement, Prying the Palm Rest: adım 26, 1 resimden 1.
    • Pry up the right side of the palm rest.
    There are a couple of latches on the front of the palm rest which should be released before you move on to the sides. I think one of those latches is released in the picture above. The iFixit opening tool was helpful here, and I used some of the iFixit opening picks to stop the corner latches from closing while I worked on others.
    BorpoIT - Yanıt
  27. Dell Vostro 3450 Hard Drive Replacement, Prying the Palm Rest: adım 27, 1 resimden 1.
    • Pry up the left side of the palm rest.
  28. Dell Vostro 3450 Hard Drive Replacement, Prying the Sides: adım 28, 1 resimden 1.
    • Pry up the sides of the palm rest and remove it from the computer.
  29. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: adım 29, 1 resimden 1.
    • Remove the screws that secure the hinge cover.
    You can skip this step, and others related to removing the display, because removing the display isn’t strictly necessary.
    Con of removing the display:
    o It takes time
    Pros of removing the display:
    o It makes it a little easier to remove the VGA card
    o The computer will tip with the weight of the display when you remove other components.
    BorpoIT - Yanıt
  30. Dell Vostro 3450 Hard Drive Replacement, Press Down on the Hooks: adım 30, 1 resimden 1.
    • Press down on the hooks highlighted in the image.
  31. Dell Vostro 3450 Hard Drive Replacement, Removing the Hinge Cover: adım 31, 1 resimden 1.
    • Flip the computer around and remove the hinge cover from the side.
  32. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: adım 32, 1 resimden 1.
    • Remove the screws that secure the display hinge.
  33. Dell Vostro 3450 Hard Drive Replacement, Loosen the Screw: adım 33, 1 resimden 1.
    • Loosen the screw that secures the low-voltage differential signaling (LVDS) cable.
  34. Dell Vostro 3450 Hard Drive Replacement, Disconnecting the LVDS Cable: adım 34, 1 resimden 1.
    • Disconnect the LVDS cable from the system board.
    By pulling it upwards?
    jeffreychc - Yanıt
    Indeed, pull straight up using the integrated handle on the connector. It required more force than I expected, and popped off suddenly once I pulled hard enough.
    BorpoIT - Yanıt
  35. Dell Vostro 3450 Hard Drive Replacement, Disconnecting the Wireless Cables: adım 35, 1 resimden 1.
    • Disconnect the wireless local area network (WLAN) antenna cable.
    You can skip this step if you decide not to remove the display.
    BorpoIT - Yanıt
  36. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: adım 36, 1 resimden 1.
    • Remove the screws that secure the left hinge.
  37. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: adım 37, 1 resimden 1.
    • Remove the screws that secure the right hinge.
  38. Dell Vostro 3450 Hard Drive Replacement, Lifting the Display Assembly: adım 38, 1 resimden 1.
    • Lift the display assembly and remove it from the computer.
  39. Dell Vostro 3450 Hard Drive Replacement, Remove the Screw: adım 39, 1 resimden 1.
    • Remove the screw that secures the WLAN card.
    BorpoIT - Yanıt
  40. Dell Vostro 3450 Hard Drive Replacement, Pull the Card: adım 40, 1 resimden 1.
    • Pull the WLAN card straight out of its socket and remove it.
    You can skip this step, it isn’t strictly necessary.
    Cons of removing the WLAN card:
    o I found the screw in the last step very stubborn, worried about stripping it.
    o Takes time.
    Pros of removing the WLAN card:
    o Might make disconnecting the system board a little easier later. I had no trouble with the WLAN card in place though.
    BorpoIT - Yanıt
  41. Dell Vostro 3450 Hard Drive Replacement, Release the Latch: adım 41, 1 resimden 1.
    • Release the latch on the system board and then disconnect the VGA cable.
  42. Dell Vostro 3450 Hard Drive Replacement, Remove the Screw: adım 42, 1 resimden 1.
    • Remove the screw that secures the VGA board.
  43. Dell Vostro 3450 Hard Drive Replacement, Remove the VGA Board: adım 43, 1 resimden 1.
    • Remove the VGA board from the chassis.
    If you decided to leave the display in place, you can just loosen the screw on the VGA board, and leave the board itself where it is. The board blocks access to a screw securing the system fan, but once you’ve removed the screw from the VGA board you can just push the VGA board out of the way and remove the system fan screw. Of course, this means the VGA board can move around while you’re working on the rest of the computer, but I didn’t find that was a big problem. You could temporarily reinstall the VGA board screw after you’ve removed the system fan.
    BorpoIT - Yanıt
  44. Dell Vostro 3450 Hard Drive Replacement, Disconnect the System Fan Cable: adım 44, 1 resimden 1.
    • Disconnect the system fan cable from the system board.
  45. Dell Vostro 3450 Hard Drive Replacement, Remove the Screw: adım 45, 1 resimden 1.
    • Remove the screw that secures the system fan.
  46. Dell Vostro 3450 Hard Drive Replacement, Remove the System Fan: adım 46, 1 resimden 1.
    • Remove the system fan from the bottom base module.
    I found this a good time to clean out dust that had accumulated around the fan.
    BorpoIT - Yanıt
  47. Dell Vostro 3450 Hard Drive Replacement, Disconnect the DC-in Cable: adım 47, 1 resimden 1.
    • Disconnect the DC-in cable connector from the system board.
    This connector is on the underside of the computer, close to the battery compartment.
    BorpoIT - Yanıt
  48. Dell Vostro 3450 Hard Drive Replacement, Disconnecting the Speaker Cable: adım 48, 1 resimden 1.
    • Disconnect the speaker cable from the system board.
  49. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: adım 49, 1 resimden 1.
    • Remove the screws that secures the system board.
    This picture shows 6 screws to be removed, but I couldn’t find 2 of them. The holes for the 4 I found were labelled B1, B2, B3, and B4.
    BorpoIT - Yanıt
  50. Dell Vostro 3450 Hard Drive Replacement, Disconnecting the System Board: adım 50, 1 resimden 1.
    • Disconnect the system board from the Input/Output panel.
    This required a fair bit of force, and I wasn’t able to do it just using my fingers. I used an iFixit Opening Tool as a lever, alternating between the two ends of the connector until it released.
    BorpoIT - Yanıt
  51. Dell Vostro 3450 Hard Drive Replacement, Remove the System Board: adım 51, 1 resimden 1.
    • Lift and remove system board from the chassis.
  52. Dell Vostro 3450 Hard Drive Replacement, Hard Drive: adım 52, 1 resimden 1.
    • Remove the screws that secures the hard drive bracket
  53. Dell Vostro 3450 Hard Drive Replacement: adım 53, 1 resimden 1.
    • Slide the hard-drive module to release it from the system board
  54. Dell Vostro 3450 Hard Drive Replacement: adım 54, 1 resimden 1.
    • Remove the hard drive module from the system board.
  55. Dell Vostro 3450 Hard Drive Replacement: adım 55, 1 resimden 1.
    • Remove the screws that secures the hard-drive bracket on one side.
  56. Dell Vostro 3450 Hard Drive Replacement: adım 56, 1 resimden 1.
    • Remove the screws that secures the hard-drive bracket on the other side
  57. Dell Vostro 3450 Hard Drive Replacement: adım 57, 1 resimden 1.
    • Slide the hard drive from the hard-drive bracket.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Johnathan Hammond
44.820 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.985 adet Kılavuz yazıldı
4 Yorum
Stupidest HDD location EVER! You have to fully disassemble your device for the simple operation.
vytookas - Yanıt
Who the !&&* designs a hard drive location that requires complete disassembly of the motherboard and the laptop to replace. Horrible, horrible design.
garbage911garbage - Yanıt
It’s possible to skip removing the display and the WLAN card, which saves a bit of time and trouble. I think I understand why this guide and Dell’s user guide recommend removing these parts, it makes other steps a _little_ easier, but I didn’t find it was worthwhile.
BorpoIT - Yanıt
I’ve done this upgrade twice now, and I think the iFixit Opening Tool (along with the spudger) makes this job easier. Besides releasing latches for the palm rest and the memory door, it was very helpful to pry up the System Board from the Input/Output Panel.
BorpoIT - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 23
Her zaman: 4,776
