Ana içeriğe geç
Dell Vostro 3450 Memory Module Replacement
Neye ihtiyacın var
  1. Dell Vostro 3450 Memory Module Replacement, Unlocking the Battery: adım 1, 1 resimden 1.
    • Slide the left and the right battery release latches to the unlock position.
  2. Dell Vostro 3450 Memory Module Replacement, Removing the Battery: adım 2, 1 resimden 1.
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3450 Memory Module Replacement, Loosen the Screw: adım 3, 1 resimden 1.
    • Loosen the screw that secures the memory door.
  4. Dell Vostro 3450 Memory Module Replacement, Removing the Memory Door: adım 4, 1 resimden 1.
    • Pry up the memory door near the screw hole, lift and remove it.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  5. Dell Vostro 3450 Memory Module Replacement, Popping up the Memory Module: adım 5, 1 resimden 1.
    • Pry the retention clips away from the memory module until it pops up.
  6. Dell Vostro 3450 Memory Module Replacement, Remove the Memory Module: adım 6, 1 resimden 1.
    • Remove the memory module from its connector on the system board.
Bitiş Çizgisi
Johnathan Hammond
45.237 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 378
