Ana içeriğe geç
Dell Vostro 3450 Memory Module Replacement
Neye ihtiyacın var
    1. Dell Vostro 3450 Memory Module Replacement, Unlocking the Battery: adım 1, 1 resimden 1.
      • Slide the left and the right battery release latches to the unlock position.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Vostro 3450 Memory Module Replacement, Removing the Battery: adım 2, 1 resimden 1.
      • Slide the battery and remove it from the computer.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Vostro 3450 Memory Module Replacement, Loosen the Screw: adım 3, 1 resimden 1.
      • Loosen the screw that secures the memory door.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Vostro 3450 Memory Module Replacement, Removing the Memory Door: adım 4, 1 resimden 1.
      • Pry up the memory door near the screw hole, lift and remove it.
      • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Vostro 3450 Memory Module Replacement, Popping up the Memory Module: adım 5, 1 resimden 1.
      • Pry the retention clips away from the memory module until it pops up.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Vostro 3450 Memory Module Replacement, Remove the Memory Module: adım 6, 1 resimden 1.
      • Remove the memory module from its connector on the system board.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
Johnathan Hammond
46.158 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
3.276 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 28
Her zaman: 648
