Ana içeriğe geç
Dell Vostro 3450 System Board Replacement
Neye ihtiyacın var
  1. Dell Vostro 3450 System Board Replacement, Unlocking the Battery: adım 1, 1 resimden 1.
    • Slide the left and the right battery release latches to the unlock position.
  2. Dell Vostro 3450 System Board Replacement, Removing the Battery: adım 2, 1 resimden 1.
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3450 System Board Replacement, Press the ExpressCard: adım 3, 1 resimden 1.
    • Press the ExpressCard to release it from the computer.
  4. Dell Vostro 3450 System Board Replacement, Slide the ExpressCard: adım 4, 1 resimden 1.
    • Slide the ExpressCard out of the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  5. Dell Vostro 3450 System Board Replacement, Prying the Keyboard: adım 5, 1 resimden 1.
    • Press the keyboard down. Pry the keyboard with the use of a flat-head screwdriver towards the display to reveal the first keyboard retainer.
  6. Dell Vostro 3450 System Board Replacement, Prying the Keyboard retainer: adım 6, 1 resimden 1.
    • Pry up the second keyboard retainer.
  7. Dell Vostro 3450 System Board Replacement, Pry up the Keyboard Retainer: adım 7, 1 resimden 1.
    • Pry up the third keyboard retainer.
  8. Dell Vostro 3450 System Board Replacement, Prying the Retainer: adım 8, 1 resimden 1.
    • Pry up the fourth keyboard retainer.
  9. Dell Vostro 3450 System Board Replacement, Pull up the Keyboard: adım 9, 1 resimden 1.
    • Pull up the keyboard from the palm rest.
  10. Dell Vostro 3450 System Board Replacement, Release the Latch: adım 10, 1 resimden 1.
    • Release the latch on the system board connector, then disconnect the keyboard cable.
  11. Dell Vostro 3450 System Board Replacement, Loosen the Screw: adım 11, 1 resimden 1.
    • Loosen the screw that secures the memory door.
  12. Dell Vostro 3450 System Board Replacement, Removing the Memory Door: adım 12, 1 resimden 1.
    • Pry up the memory door near the screw hole, lift and remove it.
  13. Dell Vostro 3450 System Board Replacement, Remove the Screw: adım 13, 1 resimden 1.
    • Remove the screw that secures the optical drive to the computer.
  14. Dell Vostro 3450 System Board Replacement, Prying the Drive: adım 14, 1 resimden 1.
    • Gently pry the optical drive out of the computer.
  15. Dell Vostro 3450 System Board Replacement, Remove the Screws: adım 15, 1 resimden 1.
    • Remove the screws that secure the optical drive bracket.
  16. Dell Vostro 3450 System Board Replacement, Removing the Optical Drive: adım 16, 1 resimden 1.
    • Remove the optical drive bracket from the optical drive module.
  17. Dell Vostro 3450 System Board Replacement, Remove the Screws: adım 17, 1 resimden 1.
    • Remove the screws in the battery compartment.
  18. Dell Vostro 3450 System Board Replacement, Remove the Screws: adım 18, 1 resimden 1.
    • Remove the screws in the optical drive compartment.
  19. Dell Vostro 3450 System Board Replacement, Remove the Rubber: adım 19, 1 resimden 1.
    • Remove the rubber from the bottom base on the right side.
  20. Dell Vostro 3450 System Board Replacement, Remove the Rubber: adım 20, 1 resimden 1.
    • Remove the rubber from the bottom base on the left side.
  21. Dell Vostro 3450 System Board Replacement, Remove the Screws: adım 21, 1 resimden 1.
    • Remove all the screws from the bottom base.
  22. Dell Vostro 3450 System Board Replacement, Remove the Screws: adım 22, 1 resimden 1.
    • Flip the computer around and remove the screws that secures the palm rest.
  23. Dell Vostro 3450 System Board Replacement, Release the Latches: adım 23, 1 resimden 1.
    • Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
  24. Dell Vostro 3450 System Board Replacement, Release the Latch: adım 24, 1 resimden 1.
    • Release the latch on the system board connector and then disconnect the power button cable.
  25. Dell Vostro 3450 System Board Replacement, Disconnecting the Key Cable: adım 25, 1 resimden 1.
    • Release the latch on the system board connector and then disconnect the hot key cable.
  26. Dell Vostro 3450 System Board Replacement, Prying the Palm Rest: adım 26, 1 resimden 1.
    • Pry up the right side of the palm rest.
  27. Dell Vostro 3450 System Board Replacement, Prying the Palm Rest: adım 27, 1 resimden 1.
    • Pry up the left side of the palm rest.
  28. Dell Vostro 3450 System Board Replacement, Prying the Sides: adım 28, 1 resimden 1.
    • Pry up the sides of the palm rest and remove it from the computer.
  29. Dell Vostro 3450 System Board Replacement, Remove the Screws: adım 29, 1 resimden 1.
    • Remove the screws that secure the hinge cover.
  30. Dell Vostro 3450 System Board Replacement, Press Down on the Hooks: adım 30, 1 resimden 1.
    • Press down on the hooks highlighted in the image.
  31. Dell Vostro 3450 System Board Replacement, Removing the Hinge Cover: adım 31, 1 resimden 1.
    • Flip the computer around and remove the hinge cover from the side.
  32. Dell Vostro 3450 System Board Replacement, Remove the Screws: adım 32, 1 resimden 1.
    • Remove the screws that secure the display hinge.
  33. Dell Vostro 3450 System Board Replacement, Loosen the Screw: adım 33, 1 resimden 1.
    • Loosen the screw that secures the low-voltage differential signaling (LVDS) cable.
  34. Dell Vostro 3450 System Board Replacement, Disconnecting the LVDS Cable: adım 34, 1 resimden 1.
    • Disconnect the LVDS cable from the system board.
  35. Dell Vostro 3450 System Board Replacement, Disconnecting the Wireless Cables: adım 35, 1 resimden 1.
    • Disconnect the wireless local area network (WLAN) antenna cable.
  36. Dell Vostro 3450 System Board Replacement, Remove the Screws: adım 36, 1 resimden 1.
    • Remove the screws that secure the left hinge.
  37. Dell Vostro 3450 System Board Replacement, Remove the Screws: adım 37, 1 resimden 1.
    • Remove the screws that secure the right hinge.
  38. Dell Vostro 3450 System Board Replacement, Lifting the Display Assembly: adım 38, 1 resimden 1.
    • Lift the display assembly and remove it from the computer.
  39. Dell Vostro 3450 System Board Replacement, Remove the Screw: adım 39, 1 resimden 1.
    • Remove the screw that secures the WLAN card.
  40. Dell Vostro 3450 System Board Replacement, Pull the Card: adım 40, 1 resimden 1.
    • Pull the WLAN card straight out of its socket and remove it.
  41. Dell Vostro 3450 System Board Replacement, Release the Latch: adım 41, 1 resimden 1.
    • Release the latch on the system board and then disconnect the VGA cable.
  42. Dell Vostro 3450 System Board Replacement, Remove the Screw: adım 42, 1 resimden 1.
    • Remove the screw that secures the VGA board.
  43. Dell Vostro 3450 System Board Replacement, Remove the VGA Board: adım 43, 1 resimden 1.
    • Remove the VGA board from the chassis.
  44. Dell Vostro 3450 System Board Replacement, Disconnect the System Fan Cable: adım 44, 1 resimden 1.
    • Disconnect the system fan cable from the system board.
  45. Dell Vostro 3450 System Board Replacement, Remove the Screw: adım 45, 1 resimden 1.
    • Remove the screw that secures the system fan.
  46. Dell Vostro 3450 System Board Replacement, Remove the System Fan: adım 46, 1 resimden 1.
    • Remove the system fan from the bottom base module.
  47. Dell Vostro 3450 System Board Replacement, Disconnect the DC-in Cable: adım 47, 1 resimden 1.
    • Disconnect the DC-in cable connector from the system board.
  48. Dell Vostro 3450 System Board Replacement, Disconnecting the Speaker Cable: adım 48, 1 resimden 1.
    • Disconnect the speaker cable from the system board.
  49. Dell Vostro 3450 System Board Replacement, Remove the Screws: adım 49, 1 resimden 1.
    • Remove the screws that secures the system board.
  50. Dell Vostro 3450 System Board Replacement, Disconnecting the System Board: adım 50, 1 resimden 1.
    • Disconnect the system board from the Input/Output panel.
  51. Dell Vostro 3450 System Board Replacement, Remove the System Board: adım 51, 1 resimden 1.
    • Lift and remove system board from the chassis.
Bitiş Çizgisi
Johnathan Hammond
45.237 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 473
