Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Slide the left and the right battery release latches to the unlock position.
Press the keyboard down. Pry the keyboard with the use of a flat-head screwdriver towards the display to reveal the first keyboard retainer.
Release the latch on the system board connector, then disconnect the keyboard cable.
Pry up the memory door near the screw hole, lift and remove it.
Remove the screw that secures the optical drive to the computer.
Remove the screws that secure the optical drive bracket.
Remove the optical drive bracket from the optical drive module.
Remove the rubber from the bottom base on the right side.
Remove the rubber from the bottom base on the left side.
Flip the computer around and remove the screws that secures the palm rest.
Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
Release the latch on the system board connector and then disconnect the power button cable.
Release the latch on the system board connector and then disconnect the hot key cable.
Pry up the sides of the palm rest and remove it from the computer.
Flip the computer around and remove the hinge cover from the side.
Loosen the screw that secures the low-voltage differential signaling (LVDS) cable.
Disconnect the wireless local area network (WLAN) antenna cable.
Lift the display assembly and remove it from the computer.
Release the latch on the system board and then disconnect the VGA cable.
Bir başkası bu kılavuzu tamamladı.
