Ana içeriğe geç
Dell Vostro 3510 Display Replacement
Neye ihtiyacın var
  1. Dell Vostro 3510 Display Replacement, Display: adım 1, 2 resimden 1. Dell Vostro 3510 Display Replacement, Display: adım 1, 2 resimden 2.
    • Ensure the laptop is powered off.
    • Flip the laptop over.
  2. Dell Vostro 3510 Display Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    Satın Al
    • Use a Phillips #0 screwdriver to remove the six 1 mm screws (circled in red).
    • Loosen the two captive 1 mm screws on the back corners.
    • Keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your laptop.
  3. Dell Vostro 3510 Display Replacement: adım 3, 2 resimden 1. Dell Vostro 3510 Display Replacement: adım 3, 2 resimden 2.
    Metal Spudger
    $2.99
    Satın Al
    • Open up the back cover of the laptop.
    • It is much easier to open up the laptop with any type of metal spudger or with Jimmy.
  4. Dell Vostro 3510 Display Replacement: adım 4, 3 resimden 1. Dell Vostro 3510 Display Replacement: adım 4, 3 resimden 2. Dell Vostro 3510 Display Replacement: adım 4, 3 resimden 3.
    • Start by unplugging the cable for display.
  5. Dell Vostro 3510 Display Replacement: adım 5, 3 resimden 1. Dell Vostro 3510 Display Replacement: adım 5, 3 resimden 2. Dell Vostro 3510 Display Replacement: adım 5, 3 resimden 3.
    • Remove the 1 mm screws in red circle with Phillips #0 screwdriver.
  6. Dell Vostro 3510 Display Replacement: adım 6, 2 resimden 1. Dell Vostro 3510 Display Replacement: adım 6, 2 resimden 2.
    • Remove the 1 mm screws holding down the metal bracket in red circle with Phillips #0 screwdriver.
  7. Dell Vostro 3510 Display Replacement: adım 7, 2 resimden 1. Dell Vostro 3510 Display Replacement: adım 7, 2 resimden 2.
    • Unplug both the white and black wire
    • The black wire is marked in red.
    • The white wire is marked in orange.
  8. Dell Vostro 3510 Display Replacement: adım 8, 3 resimden 1. Dell Vostro 3510 Display Replacement: adım 8, 3 resimden 2. Dell Vostro 3510 Display Replacement: adım 8, 3 resimden 3.
    • Lift up the hinges circled in red.
  9. Dell Vostro 3510 Display Replacement: adım 9, 2 resimden 1. Dell Vostro 3510 Display Replacement: adım 9, 2 resimden 2.
    • Hold it at a angle and then it should slide off.
Sonuç
Jhoan Cruz
483 İtibar
3 adet Kılavuz yazıldı
Ekip
Gateway, Team 16-1, Gonzalez Spring 2024 Gateway, Team 16-1, Gonzalez Spring 2024 üyesi
GCC-GONZALEZ-S24S16G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 42
Her zaman: 52
