Ana içeriğe geç
Dell Vostro 3550 Disk Drive Tray Latch Replacement
Neye ihtiyacın var
  1. Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: adım 1, 3 resimden 1. Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: adım 1, 3 resimden 2. Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: adım 1, 3 resimden 3.
    • Push a paperclip that is bent straight into the small pin hole on the right of the release button.
    • When 3/4" of the paperclip is inserted the tray will pop open.
    • Pull the disk tray out as far as it will extend.
  2. Dell Vostro 3550 Disk Drive Tray Latch Replacement: adım 2, 3 resimden 1. Dell Vostro 3550 Disk Drive Tray Latch Replacement: adım 2, 3 resimden 2. Dell Vostro 3550 Disk Drive Tray Latch Replacement: adım 2, 3 resimden 3.
    • Flip the laptop over and position it so the disk drive is in front of you.
    • Remove the five 5mm Phillips #0 screws fastening the top plate to the disk tray.
  3. Dell Vostro 3550 Disk Drive Tray Latch Replacement: adım 3, 3 resimden 1. Dell Vostro 3550 Disk Drive Tray Latch Replacement: adım 3, 3 resimden 2. Dell Vostro 3550 Disk Drive Tray Latch Replacement: adım 3, 3 resimden 3.
    • Remove the top plate of the disk tray and place it off to the side.
  4. Dell Vostro 3550 Disk Drive Tray Latch Replacement: adım 4, 3 resimden 1. Dell Vostro 3550 Disk Drive Tray Latch Replacement: adım 4, 3 resimden 2. Dell Vostro 3550 Disk Drive Tray Latch Replacement: adım 4, 3 resimden 3.
    • Remove the single 5mm Phillips #0 screw securing the latch mechanism to the disk drive.
    • Pull the damaged latch away from the disk drive and replace with the new latch.
Sonuç
Dylan J. Souza
781 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S8-G6, Bailey Spring 2019 UMass Dartmouth, Team S8-G6, Bailey Spring 2019 üyesi
UMASSD-BAILEY-S19S8G6
3 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 289
