Ana içeriğe geç
Dell Vostro 3550 Display Assembly Replacement
Neye ihtiyacın var
  1. Dell Vostro 3550 Display Assembly Replacement, Display Assembly: adım 1, 2 resimden 1. Dell Vostro 3550 Display Assembly Replacement, Display Assembly: adım 1, 2 resimden 2.
    • Grip the back trim of the laptop and pull upwards to remove it.
  2. Dell Vostro 3550 Display Assembly Replacement: adım 2, 3 resimden 1. Dell Vostro 3550 Display Assembly Replacement: adım 2, 3 resimden 2. Dell Vostro 3550 Display Assembly Replacement: adım 2, 3 resimden 3.
    • Slide the plastic opening tool around the perimeter of the display bezel.
    • Carefully remove the bezel from the display.
  3. Dell Vostro 3550 Display Assembly Replacement: adım 3, 3 resimden 1. Dell Vostro 3550 Display Assembly Replacement: adım 3, 3 resimden 2. Dell Vostro 3550 Display Assembly Replacement: adım 3, 3 resimden 3.
    • Remove the six 7 mm Phillips #0 screws attaching the display to the upper casing of the laptop.
    • When all six screws are removed, gently lower the display to reveal the camera cable.
  4. Dell Vostro 3550 Display Assembly Replacement: adım 4, 3 resimden 1. Dell Vostro 3550 Display Assembly Replacement: adım 4, 3 resimden 2. Dell Vostro 3550 Display Assembly Replacement: adım 4, 3 resimden 3.
    • Disconnect the camera ribbon cable by gently pulling it away from its connector.
  5. Dell Vostro 3550 Display Assembly Replacement: adım 5, 2 resimden 1. Dell Vostro 3550 Display Assembly Replacement: adım 5, 2 resimden 2.
    • Remove the four 5 mm Phillips #0 screws (two on either side) securing the display to the metal frame.
  6. Dell Vostro 3550 Display Assembly Replacement: adım 6, 3 resimden 1. Dell Vostro 3550 Display Assembly Replacement: adım 6, 3 resimden 2. Dell Vostro 3550 Display Assembly Replacement: adım 6, 3 resimden 3.
    • Gently lower the display into a resting position.
  7. Dell Vostro 3550 Display Assembly Replacement: adım 7, 3 resimden 1. Dell Vostro 3550 Display Assembly Replacement: adım 7, 3 resimden 2. Dell Vostro 3550 Display Assembly Replacement: adım 7, 3 resimden 3.
    • Loosen the clear tape fastening the ribbon cable to the display.
    • Carefully pull the ribbon cable away from the connector.
  8. Dell Vostro 3550 Display Assembly Replacement: adım 8, 3 resimden 1. Dell Vostro 3550 Display Assembly Replacement: adım 8, 3 resimden 2. Dell Vostro 3550 Display Assembly Replacement: adım 8, 3 resimden 3.
    • Peel the ribbon cable away from the display.
    • Remove the display from the laptop.
Sonuç
Dylan J. Souza
781 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S8-G6, Bailey Spring 2019 UMass Dartmouth, Team S8-G6, Bailey Spring 2019 üyesi
UMASSD-BAILEY-S19S8G6
3 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 856
