Ana içeriğe geç
Dell Vostro 3555 Memory Module Replacement
Neye ihtiyacın var
    1. Dell Vostro 3555 Memory Module Replacement, Unlocking the Battery: adım 1, 1 resimden 1.
      • Slide the release latches to unlock the battery.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Vostro 3555 Memory Module Replacement, Removing the Battery: adım 2, 1 resimden 1.
      • Slide the battery and remove it from the computer.
      • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Vostro 3555 Memory Module Replacement, Remove the Screws: adım 3, 1 resimden 1.
      • Remove the screws that secure the access panel to the base of the computer.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Vostro 3555 Memory Module Replacement, Lifting the Access Panel: adım 4, 1 resimden 1.
      • Lift the access panel up at an angle and remove it from the computer.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Vostro 3555 Memory Module Replacement, Memory Module: adım 5, 1 resimden 1.
      • Pry the retention clips away from the memory module until it pops up.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Vostro 3555 Memory Module Replacement: adım 6, 1 resimden 1.
      • Remove the memory module from its connector on the system board.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Johnathan Hammond
46.158 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
4.986 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 255
