Ana içeriğe geç
Dell Vostro 3559 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Vostro 3559 Hard Drive Replacement, Sliding the Latch: adım 1, 1 resimden 1.
    • Slide the release latch outwards to unlock the battery.
  2. Dell Vostro 3559 Hard Drive Replacement, Remove the Battery: adım 2, 1 resimden 1.
    • Remove the battery from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Dell Vostro 3559 Hard Drive Replacement, Remove the Screws: adım 3, 1 resimden 1.
    • Remove the screws that secure the access panel to the computer.
    • Lift the access panel partially at a 45–degree angle.
  4. Dell Vostro 3559 Hard Drive Replacement, Remove the Access Panel: adım 4, 1 resimden 1.
    • Remove the access panel from the computer.
  5. Dell Vostro 3559 Hard Drive Replacement, Removing the Hard Drive Cable: adım 5, 1 resimden 1.
    • Disconnect the hard drive cable from the system board and lift it up to remove it from the computer.
    • Remove the screws that secure the hard drive to the computer.
  6. Dell Vostro 3559 Hard Drive Replacement: adım 6, 1 resimden 1.
    • Lift the hard drive to remove it from the computer [1,2].
  7. Dell Vostro 3559 Hard Drive Replacement, Remove the Screws: adım 7, 1 resimden 1.
    • Remove the screws that secure the hard drive to the bracket.
    • Lift the hard drive from the bracket.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Johnathan Hammond
45.237 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0 Guide Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 469
