Giriş
In this guide, we will be showing you how to remove and replace the Memory Module.
Neye ihtiyacın var
Remove the screws that secure the access panel to the computer.
Lift the access panel partially at a 45–degree angle.
Pry the securing clips away from the memory module until it pops up.
Remove the memory module from its socket on the system board.
Bir başkası bu kılavuzu tamamladı.
