Ana içeriğe geç
Dell Vostro 3560 Optical Drive Replacement
Neye ihtiyacın var
  1. Dell Vostro 3560 Optical Drive Replacement, Identify your laptop: adım 1, 2 resimden 1. Dell Vostro 3560 Optical Drive Replacement, Identify your laptop: adım 1, 2 resimden 2.
    • Make sure you have the right laptop by checking the sticker.
  2. Dell Vostro 3560 Optical Drive Replacement, Remove Battery: adım 2, 2 resimden 1. Dell Vostro 3560 Optical Drive Replacement, Remove Battery: adım 2, 2 resimden 2.
    • Start with your PC shut off and upside down.
    • Pull out tabs.
    • Pull up on rail to remove battery.
  3. Dell Vostro 3560 Optical Drive Replacement, Remove Back Panel: adım 3, 1 resimden 1.
    • Remove the two screws:
    • One M2 Phillips screw (Fixed)
    • One 5-mm M2 Phillips screw
  4. Dell Vostro 3560 Optical Drive Replacement: adım 4, 3 resimden 1. Dell Vostro 3560 Optical Drive Replacement: adım 4, 3 resimden 2. Dell Vostro 3560 Optical Drive Replacement: adım 4, 3 resimden 3.
    • Use a iFixit opening tool to remove the back panel.
  5. Dell Vostro 3560 Optical Drive Replacement: adım 5, 1 resimden 1.
    • From here you can access:
    • The hard drive
    • The RAM.
    • The CD Drive.
  6. Dell Vostro 3560 Optical Drive Replacement, Optical Drive: adım 6, 1 resimden 1.
    • We will focus on the Optical Drive.
  7. Dell Vostro 3560 Optical Drive Replacement, Remove Optical Drive: adım 7, 1 resimden 1.
    • Remove the 3-mm M2 Phillips screws.
  8. Dell Vostro 3560 Optical Drive Replacement: adım 8, 3 resimden 1. Dell Vostro 3560 Optical Drive Replacement: adım 8, 3 resimden 2. Dell Vostro 3560 Optical Drive Replacement: adım 8, 3 resimden 3.
    • Pull the optical drive out of the frame.
    • If it doesn't come out immediately, you might have to shake it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Max Bareilles
664 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 440
