Ana içeriğe geç
Dell Vostro 3561 Memory Module Replacement
Neye ihtiyacın var
  1. Dell Vostro 3561 Memory Module Replacement, Sliding the Battery Release Latch: adım 1, 1 resimden 1.
    • Flip the computer over.
    • Slide the battery release latch to the unlock position.
  2. Dell Vostro 3561 Memory Module Replacement, Slide the Battery Release Latch: adım 2, 1 resimden 1.
    • Slide the other battery release latch to the unlock position.
  3. Dell Vostro 3561 Memory Module Replacement, Removing the Battery: adım 3, 1 resimden 1.
    • Slide the battery and remove it from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  4. Dell Vostro 3561 Memory Module Replacement, Remove the Screws: adım 4, 1 resimden 1.
    • Remove the screws that secure the base cover to the computer.
  5. Dell Vostro 3561 Memory Module Replacement, Removing the Base Cover: adım 5, 1 resimden 1.
    • Lift up the base cover and remove it from the computer.
  6. Dell Vostro 3561 Memory Module Replacement, Releasing the Memory Module: adım 6, 1 resimden 1.
    • Push apart the memory retention clips to release the memory module.
  7. Dell Vostro 3561 Memory Module Replacement, Removing the Memory Module: adım 7, 1 resimden 1.
    • Remove the memory module from its connector on the system board.
Bitiş Çizgisi
Johnathan Hammond
45.237 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 621
