Ana içeriğe geç
Dell Vostro 3561 Memory Module Replacement
Neye ihtiyacın var
    1. Dell Vostro 3561 Memory Module Replacement, Sliding the Battery Release Latch: adım 1, 1 resimden 1.
      • Flip the computer over.
      • Slide the battery release latch to the unlock position.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Vostro 3561 Memory Module Replacement, Slide the Battery Release Latch: adım 2, 1 resimden 1.
      • Slide the other battery release latch to the unlock position.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Vostro 3561 Memory Module Replacement, Removing the Battery: adım 3, 1 resimden 1.
      • Slide the battery and remove it from the computer.
      • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Vostro 3561 Memory Module Replacement, Remove the Screws: adım 4, 1 resimden 1.
      • Remove the screws that secure the base cover to the computer.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Vostro 3561 Memory Module Replacement, Removing the Base Cover: adım 5, 1 resimden 1.
      • Lift up the base cover and remove it from the computer.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Vostro 3561 Memory Module Replacement, Releasing the Memory Module: adım 6, 1 resimden 1.
      • Push apart the memory retention clips to release the memory module.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Vostro 3561 Memory Module Replacement, Removing the Memory Module: adım 7, 1 resimden 1.
      • Remove the memory module from its connector on the system board.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
Johnathan Hammond
46.185 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
12.124 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 29
Her zaman: 925
