Ana içeriğe geç
Dell Vostro 500 Memory Module Replacement
Neye ihtiyacın var
    1. Dell Vostro 500 Memory Module Replacement, Removing the Battery: adım 1, 1 resimden 1.
      • Slide the battery release latch toward the side of the computer until it is engaged.
      • Slide the battery out of the bay.
      • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Vostro 500 Memory Module Replacement, Removing the Cover: adım 2, 1 resimden 1.
      • Turn the computer upside-down, loosen the eight captive screws on the cover and remove the cover.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Vostro 500 Memory Module Replacement, Popping up the Memory Module: adım 3, 1 resimden 1.
      • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
      • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
      • Remove the module from the connector.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
Johnathan Hammond
46.158 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
4.986 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 30
Her zaman: 339
