Ana içeriğe geç
Dell Vostro 5470 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Vostro 5470 Hard Drive Replacement, Remove the Screws: adım 1, 1 resimden 1.
    • Remove the screws that secure the base cover to the computer.
  2. Dell Vostro 5470 Hard Drive Replacement, Loosening the Base Cover: adım 2, 1 resimden 1.
    • Pry the base cover along the edges to loosen it.
  3. Dell Vostro 5470 Hard Drive Replacement, Removing the Base Cover: adım 3, 1 resimden 1.
    • Lift and remove the base cover from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  4. Dell Vostro 5470 Hard Drive Replacement, Disconnecting the Battery Cable: adım 4, 1 resimden 1.
    • Disconnect the battery cable from its connector on the system board.
  5. Dell Vostro 5470 Hard Drive Replacement, Releasing the Tabs: adım 5, 1 resimden 1.
    • Release the tabs that secure the battery in the battery bay.
  6. Dell Vostro 5470 Hard Drive Replacement, Removing the Battery: adım 6, 1 resimden 1.
    • Lift and remove the battery from the computer.
  7. Dell Vostro 5470 Hard Drive Replacement, Hard Drive: adım 7, 1 resimden 1.
    • Lift the hard drive assembly in an upward direction to release it from its compartment on the computer. Remove the hard drive from the computer.
  8. Dell Vostro 5470 Hard Drive Replacement: adım 8, 1 resimden 1.
    • Remove the screws that secure the hard drive to the hard drive assembly.
    • Lift and remove the hard drive from the hard drive assembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Johnathan Hammond
45.058 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.984 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 1,667
