Ana içeriğe geç
Dell Vostro 5470 Memory Module Replacement
Neye ihtiyacın var
  1. Dell Vostro 5470 Memory Module Replacement, Remove the Screws: adım 1, 1 resimden 1.
    • Remove the screws that secure the base cover to the computer.
  2. Dell Vostro 5470 Memory Module Replacement, Loosening the Base Cover: adım 2, 1 resimden 1.
    • Pry the base cover along the edges to loosen it.
  3. Dell Vostro 5470 Memory Module Replacement, Removing the Base Cover: adım 3, 1 resimden 1.
    • Lift and remove the base cover from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  4. Dell Vostro 5470 Memory Module Replacement, Disconnecting the Battery Cable: adım 4, 1 resimden 1.
    • Disconnect the battery cable from its connector on the system board.
  5. Dell Vostro 5470 Memory Module Replacement, Releasing the Tabs: adım 5, 1 resimden 1.
    • Release the tabs that secure the battery in the battery bay.
  6. Dell Vostro 5470 Memory Module Replacement, Removing the Battery: adım 6, 1 resimden 1.
    • Lift and remove the battery from the computer.
  7. Dell Vostro 5470 Memory Module Replacement, Memory Module: adım 7, 1 resimden 1.
    • Pry the securing clips away from the memory module until it pops up. Remove the memory module from its connector on the system board.
Sonuç
Johnathan Hammond
44.830 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.985 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 960
