Ana içeriğe geç
Dell Vostro 5510 Fan Replacement
Neye ihtiyacın var
  1. Dell Vostro 5510 Fan Replacement, Back Cover: adım 1, 1 resimden 1.
    • Power off your laptop before beginning disassembly.
    • Place the laptop so the bottom cover is facing upwards.
  2. Dell Vostro 5510 Fan Replacement: adım 2, 1 resimden 1.
    • Remove the remaining (M2x4mm) screws with the screwdriver.
    • Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
  3. Dell Vostro 5510 Fan Replacement: adım 3, 3 resimden 1. Dell Vostro 5510 Fan Replacement: adım 3, 3 resimden 2. Dell Vostro 5510 Fan Replacement: adım 3, 3 resimden 3.
    • Pry open the top left corner of the cover with the opening tool.
    • Pry open the top right corner of the cover with the opening tool.
    • Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
  4. Dell Vostro 5510 Fan Replacement: adım 4, 3 resimden 1. Dell Vostro 5510 Fan Replacement: adım 4, 3 resimden 2. Dell Vostro 5510 Fan Replacement: adım 4, 3 resimden 3.
    • Lift the cover to remove it from the rest of the laptop.
  5. Dell Vostro 5510 Fan Replacement, Fan: adım 5, 3 resimden 1. Dell Vostro 5510 Fan Replacement, Fan: adım 5, 3 resimden 2. Dell Vostro 5510 Fan Replacement, Fan: adım 5, 3 resimden 3.
    • Disconnect the fan cable from the system board.
  6. Dell Vostro 5510 Fan Replacement: adım 6, 3 resimden 1. Dell Vostro 5510 Fan Replacement: adım 6, 3 resimden 2. Dell Vostro 5510 Fan Replacement: adım 6, 3 resimden 3.
    • Remove the two (M2x3mm) screws from the fan using the screwdriver.
  7. Dell Vostro 5510 Fan Replacement: adım 7, 2 resimden 1. Dell Vostro 5510 Fan Replacement: adım 7, 2 resimden 2.
    • Lift the fan to remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ky Vang
378 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 148
