Ana içeriğe geç
Dell Vostro 5560 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Vostro 5560 Hard Drive Replacement, Removing The Optical-Disk Drive: adım 1, 1 resimden 1.
    • Remove the screw that secures the base cover to the computer.
    • Pull the optical-drive and remove from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro 5560 Hard Drive Replacement, Replacing the Base Cover: adım 2, 2 resimden 1. Dell Vostro 5560 Hard Drive Replacement, Replacing the Base Cover: adım 2, 2 resimden 2.
    • Remove the screws that secure the base cover to the computer.
    • Pry the base cover along the edges to loosen it. Lift and remove the base cover from the computer.
  3. Dell Vostro 5560 Hard Drive Replacement, Removing the Battery: adım 3, 1 resimden 1.
    • Disconnect the battery cable from its connector on the system board.
    • Lift and remove the battery from the computer.
  4. Dell Vostro 5560 Hard Drive Replacement, Disconnecting the Hard Drive: adım 4, 1 resimden 1.
    • Ease the I/O cable from the routing tabs.
    • Disconnect the hard-drive cable from the system board and remove the screws that secures the hard-drive in place
    • Lift and remove the hard-drive from the computer
  5. Dell Vostro 5560 Hard Drive Replacement, Disconnecting the Hard Drive Connector: adım 5, 1 resimden 1.
    • Disconnect the hard-drive connector from hard drive.
  6. Dell Vostro 5560 Hard Drive Replacement, Remove the Screws: adım 6, 1 resimden 1.
    • Remove the screws that secure the hard-drive bracket to the hard drive. Separate the hard-drive bracket from the hard drive.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Johnathan Hammond
45.058 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.984 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 226
