Neye ihtiyacın var
Remove the screw that secures the base cover to the computer.
Pull the optical-drive and remove from the computer.
Remove the screws that secure the base cover to the computer.
Pry the base cover along the edges to loosen it. Lift and remove the base cover from the computer.
Disconnect the battery cable from its connector on the system board.
Lift and remove the battery from the computer.
Pry the securing clips away from the memory module until it pops-up. Remove the memory module from its connector on the system board.
Bir başkası bu kılavuzu tamamladı.
