Ana içeriğe geç
Dell Vostro 5560 Memory Module Replacement
Neye ihtiyacın var
    1. Dell Vostro 5560 Memory Module Replacement, Removing The Optical-Disk Drive: adım 1, 1 resimden 1.
      • Remove the screw that secures the base cover to the computer.
      • Pull the optical-drive and remove from the computer.
      • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Vostro 5560 Memory Module Replacement, Replacing the Base Cover: adım 2, 2 resimden 1. Dell Vostro 5560 Memory Module Replacement, Replacing the Base Cover: adım 2, 2 resimden 2.
      • Remove the screws that secure the base cover to the computer.
      • Pry the base cover along the edges to loosen it. Lift and remove the base cover from the computer.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Vostro 5560 Memory Module Replacement, Removing the Battery: adım 3, 1 resimden 1.
      • Disconnect the battery cable from its connector on the system board.
      • Lift and remove the battery from the computer.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Vostro 5560 Memory Module Replacement, Removing the Memory Module: adım 4, 1 resimden 1.
      • Pry the securing clips away from the memory module until it pops-up. Remove the memory module from its connector on the system board.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Johnathan Hammond
46.158 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
11.849 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 328
