Ana içeriğe geç
Dell Vostro A840 Memory Module Replacement
Neye ihtiyacın var
  1. Dell Vostro A840 Memory Module Replacement, Remove the battery: adım 1, 1 resimden 1.
    • Unlock the battery by sliding the battery-lock latch towards the outer edge.
    • Slide the battery-bay release latch and hold it.
    • Remove the battery from the battery bay.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro A840 Memory Module Replacement, Remove the Module Cover: adım 2, 1 resimden 1.
    • Remove the two screws from the module cover.
    • Lift the module cover away from the computer.
  3. Dell Vostro A840 Memory Module Replacement, Removing the Memory Module: adım 3, 1 resimden 1.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the module from the connector.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Johnathan Hammond
44.830 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.985 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 45
