Ana içeriğe geç
Dell Vostro A860 Power Button Replacement
Neye ihtiyacın var
    1. Dell Vostro A860 Power Button Replacement, Keyboard: adım 1, 2 resimden 1. Dell Vostro A860 Power Button Replacement, Keyboard: adım 1, 2 resimden 2.
      • Make sure the computer is powered down before beginning your work
      • Remove the battery and set it aside, there is a small clip that slides to free the battery.
      • Unscrew the two 4.7mm screws below the battery.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Vostro A860 Power Button Replacement: adım 2, 2 resimden 1. Dell Vostro A860 Power Button Replacement: adım 2, 2 resimden 2.
      • Remove seven 8.6mm screws from the left and right side of the battery compartment
      • There are 2 screws to the left of the compartment, 3 to the right, and 2 along the bottom side.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Vostro A860 Power Button Replacement: adım 3, 3 resimden 1. Dell Vostro A860 Power Button Replacement: adım 3, 3 resimden 2. Dell Vostro A860 Power Button Replacement: adım 3, 3 resimden 3.
      • Flip the laptop over and open it up.
      • Using a plastic opening tool carefully pry up along the edge of the plastic bezel at the top of the keyboard.
      • Getting the lip of the plastic opening tool under the edge of the bezel and moving it along the right and left edges helps to make removal easier.
      FixBot'a Sor
      Yorum Ekle
    4. Dell Vostro A860 Power Button Replacement: adım 4, 2 resimden 1. Dell Vostro A860 Power Button Replacement: adım 4, 2 resimden 2.
      • Remove two 5.5mm screws from the top of the keyboard
      • Using a plastic opening tool push inward along the edges of the keyboard to release the holding clips
      FixBot'a Sor
      Yorum Ekle
    5. Dell Vostro A860 Power Button Replacement: adım 5, 1 resimden 1.
      • Lift the keyboard upwards
      • Be careful not to pull too hard on the keyboard as it is still attached to the laptop by the ribbon connector.
      • Using the plastic opening tool push up on the black clip holding the connector ribbon.
      • Pull out the ribbon connector to remove the keyboard.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Vostro A860 Power Button Replacement, Power Button: adım 6, 1 resimden 1.
      • With the keyboard removed use the plastic opening tool to lift the black clip holding the connector ribbon for the power switch.
      • Gently pull out the connector ribbon from the inlet using the attached plastic pull
      FixBot'a Sor
      Yorum Ekle
    2. Dell Vostro A860 Power Button Replacement: adım 7, 1 resimden 1.
      • Using a plastic opening tool carefully pull apart the clips holding in the power button and control unit.
      • There are four clips holding the button unit facing inward. Two push down clips hold the control unit.
      • Slide the power under the screen cables to remove.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Joshua Dennis
528 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-5, Miles Spring 2016 UMass Dartmouth, Team 1-5, Miles Spring 2016 üyesi
UMASSD-MILES-S16S1G5
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 21
Her zaman: 797
