Ana içeriğe geç
Dell Vostro V13 Sound Card Replacement
Neye ihtiyacın var
  1. Dell Vostro V13 Sound Card Replacement, Back Cover: adım 1, 3 resimden 1. Dell Vostro V13 Sound Card Replacement, Back Cover: adım 1, 3 resimden 2. Dell Vostro V13 Sound Card Replacement, Back Cover: adım 1, 3 resimden 3.
    • Back up the memory to an external drive and power off the laptop before starting.
    • Flip the laptop over so the vents are facing you.
    • Remove the six 5.0 mm Phillips #1 screws using the magnetic driver.
    • Remove the two 5.0 mm Phillips #1 screws on the back side of the laptop.
  2. Dell Vostro V13 Sound Card Replacement: adım 2, 3 resimden 1. Dell Vostro V13 Sound Card Replacement: adım 2, 3 resimden 2. Dell Vostro V13 Sound Card Replacement: adım 2, 3 resimden 3.
    • Slide out the SD and MicroSD holders.
    • If you are having trouble sliding them out, use the plastic opening tool.
  3. Dell Vostro V13 Sound Card Replacement: adım 3, 3 resimden 1. Dell Vostro V13 Sound Card Replacement: adım 3, 3 resimden 2. Dell Vostro V13 Sound Card Replacement: adım 3, 3 resimden 3.
    • Slide the plastic opening tool around the perimeter of the laptop until the cover pops off.
    • Pull the back cover off.
  4. Dell Vostro V13 Sound Card Replacement: adım 4, 2 resimden 1. Dell Vostro V13 Sound Card Replacement: adım 4, 2 resimden 2.
    • Remove the three black 3.9 mm Phillips #1 screws holding the battery in place.
  5. Dell Vostro V13 Sound Card Replacement: adım 5, 3 resimden 1. Dell Vostro V13 Sound Card Replacement: adım 5, 3 resimden 2. Dell Vostro V13 Sound Card Replacement: adım 5, 3 resimden 3.
    • Flip up the clip of the ribbon connector.
    • Pull the strip out to disconnect the battery.
  6. Dell Vostro V13 Sound Card Replacement: adım 6, 2 resimden 1. Dell Vostro V13 Sound Card Replacement: adım 6, 2 resimden 2.
    • Remove the battery.
    • Removing the battery allows you to work safely.
  7. Dell Vostro V13 Sound Card Replacement, Sound Card: adım 7, 2 resimden 1. Dell Vostro V13 Sound Card Replacement, Sound Card: adım 7, 2 resimden 2.
    • Remove the black 3.0 mm Phillips #1 screw.
    • Remove the two 5.1 mm silver Phillips #1 screws.
  8. Dell Vostro V13 Sound Card Replacement: adım 8, 2 resimden 1. Dell Vostro V13 Sound Card Replacement: adım 8, 2 resimden 2.
    • Disconnect the white plug on the top left corner of the sound card.
  9. Dell Vostro V13 Sound Card Replacement: adım 9, 2 resimden 1. Dell Vostro V13 Sound Card Replacement: adım 9, 2 resimden 2.
    • Use the plastic opening tool to flip the ribbon connector up.
  10. Dell Vostro V13 Sound Card Replacement: adım 10, 2 resimden 1. Dell Vostro V13 Sound Card Replacement: adım 10, 2 resimden 2.
    • Pull the sound card out of the laptop.
Sonuç
Patrick Swaney
363 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 781
