Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
In this guide, we will be showing you how to remove the Hard Drive and Audio Board.
Parçalar
Hiçbir parça belirtilmedi.
  1. Remove the screws that secure the base cover to the computer.
    • Remove the screws that secure the base cover to the computer.
  2. Slide the base cover towards the front of the computer. Lift it up and away from the computer.
    • Slide the base cover towards the front of the computer. Lift it up and away from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
    • Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
  4. Remove the screws that secure the battery to the computer.
    • Remove the screws that secure the battery to the computer.
  5. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  6. Lift the battery up and away from the computer.
    • Lift the battery up and away from the computer.
  7. Disconnect the speaker and system board cables from the audio board.
    • Disconnect the speaker and system board cables from the audio board.
  8. Remove the screws that secure the audio board and the hard drive to the computer.
    • Remove the screws that secure the audio board and the hard drive to the computer.
  9. Lift and remove the hard drive and audio board assembly from the computer.
    • Lift and remove the hard drive and audio board assembly from the computer.
  10. Slide the audio board from the hard drive.
    • Slide the audio board from the hard drive.
  11. Remove the screws that secure the hard-drive bracket to the hard drive.
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  12. Remove the hard drive from the hard-drive bracket.
    • Remove the hard drive from the hard-drive bracket.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Johnathan Hammond
37.166 İtibar
408 adet Kılavuz yazıldı
Takım
Informative Technologies Inc. Informative Technologies Inc. üyesi
Community
21 Üyeler
1.816 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 302
