Giriş
In this guide, we will show you how to remove and replace the LED Cover.
Neye ihtiyacın var
Slide the base cover towards the front of the computer. Lift it up and away from the computer.
If this is all you are doing Follow Step In Reverse if not Go to Next Step.
Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
Starting on the right side of the system, use a plastic scribe to pry up the LED cover from the computer.
Pull the LED cover toward the keyboard and remove it from the computer.
Bir başkası bu kılavuzu tamamladı.
