Ana içeriğe geç
Dell Vostro V130 Memory Module Replacement
Neye ihtiyacın var
  1. Dell Vostro V130 Memory Module Replacement, Remove the Screws: adım 1, 1 resimden 1.
    • Remove the screws that secure the base cover to the computer.
  2. Dell Vostro V130 Memory Module Replacement, Removing the Base Cover: adım 2, 1 resimden 1.
    • Slide the base cover towards the front of the computer. Lift it up and away from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Dell Vostro V130 Memory Module Replacement, Disconnecting the Battery: adım 3, 1 resimden 1.
    • Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
  4. Dell Vostro V130 Memory Module Replacement, Remove Battery Screws: adım 4, 1 resimden 1.
    • Remove the screws that secure the battery to the computer.
  5. Dell Vostro V130 Memory Module Replacement, Lift the Battery: adım 5, 1 resimden 1.
    • Lift the battery up and away from the computer.
  6. Dell Vostro V130 Memory Module Replacement, LED Cover: adım 6, 1 resimden 1.
    • Starting on the right side of the system, use a plastic scribe to pry up the LED cover from the computer.
  7. Dell Vostro V130 Memory Module Replacement, Removing the LED Cover: adım 7, 1 resimden 1.
    • Pull the LED cover toward the keyboard and remove it from the computer.
  8. Dell Vostro V130 Memory Module Replacement, Memory Module: adım 8, 1 resimden 1.
    • Use your fingertips to spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  9. Dell Vostro V130 Memory Module Replacement: adım 9, 1 resimden 1.
    • Remove the memory module from its connector on the system board by drawing the module from the system board at 45-degree angle.
Bitiş Çizgisi
Johnathan Hammond
46.134 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
1.999 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 36
Her zaman: 538
