Ana içeriğe geç
Dell Wyse Xn0m Battery Replacement
Neye ihtiyacın var
  1. Dell Wyse Xn0m Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Identify the location of the battery release switches.
  2. Dell Wyse Xn0m Battery Replacement: adım 2, 1 resimden 1.
    • Slide the left battery release switch to the unlocked position (red showing). This is also indicated by the lock/unlock icons beside the switch.
  3. Dell Wyse Xn0m Battery Replacement: adım 3, 2 resimden 1. Dell Wyse Xn0m Battery Replacement: adım 3, 2 resimden 2.
    • To remove the battery, pull back the right spring-loaded battery release switch while simultaneously sliding the battery away from the laptop.
    • Reassembly tip: when inserting the new battery, make sure the tracks line up right. The battery tracks should sit on top of the laptop body tracks.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sam Horne
109 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 18
Her zaman: 1,135
