Ana içeriğe geç
Dell Wyse Xn0m Fan Replacement
Neye ihtiyacın var
  1. Dell Wyse Xn0m Fan Replacement, Fan: adım 1, 3 resimden 1. Dell Wyse Xn0m Fan Replacement, Fan: adım 1, 3 resimden 2. Dell Wyse Xn0m Fan Replacement, Fan: adım 1, 3 resimden 3.
    • Use a spudger to unclip the keyboard from the main body by disengaging the clips lined around the top and sides of the keyboard.
    • Once lifted, push the white slider holding blue ribbon cable and put keyboard to the side.
  2. Dell Wyse Xn0m Fan Replacement: adım 2, 1 resimden 1.
    • With the spudger, remove sliders that are holding the purple ribbon cable.
    • Disconnect cable by the power button.
  3. Dell Wyse Xn0m Fan Replacement: adım 3, 1 resimden 1.
    • Remove the five 7mm Phillips #1 screws underneath the keyboard.
  4. Dell Wyse Xn0m Fan Replacement: adım 4, 1 resimden 1.
    • Close the laptop and flip it over.
    • Remove eight 7mm Phillips #1 screws along the edges of laptop.
    • Put these screws to the side (make sure to keep them apart from keyboard screws).
  5. Dell Wyse Xn0m Fan Replacement: adım 5, 1 resimden 1.
    • After removing the screws, flip the laptop back over and open the screen.
    • Lift the laptop's keyboard/mouse pad top with an opening tool.
  6. Dell Wyse Xn0m Fan Replacement: adım 6, 2 resimden 1. Dell Wyse Xn0m Fan Replacement: adım 6, 2 resimden 2.
    • Unplug the cable connecting the fan to the motherboard.
    • Lift the tape holding down the cables over the fan.
    • Undo two 5mm Phillips #1 screws.
    • The top left screw is covered by the cables. Use a spudger to get it out of the way.
    • Lift the fan out of its slot.
Sonuç
The process is simple but tedious. Be patient, keep the screws organized, be gentle with the clips and you are good to go!
2 farklı kişi bu kılavuzu tamamladı.
Daniel Hill
172 İtibar
1 Kılavuz yazıldı
Bir Yorum
excelent work. thanks for share
Asimple Guy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 15
Her zaman: 946
