Ana içeriğe geç
Dell Wyse Xn0m Mouse Sensor Board Replacement
Neye ihtiyacın var
  1. Dell Wyse Xn0m Mouse Sensor Board Replacement, Mouse Sensor Board: adım 1, 1 resimden 1.
    • Flip the device over. Unscrew nine marked 7mm Phillips #1 screws.
  2. Dell Wyse Xn0m Mouse Sensor Board Replacement: adım 2, 2 resimden 1. Dell Wyse Xn0m Mouse Sensor Board Replacement: adım 2, 2 resimden 2.
    • Remove the keyboard by pushing back the tabs at the marked locations with a spudger or plastic opening tool.
  3. Dell Wyse Xn0m Mouse Sensor Board Replacement: adım 3, 2 resimden 1. Dell Wyse Xn0m Mouse Sensor Board Replacement: adım 3, 2 resimden 2.
    • Turn the device around so the screen is closest to you. Lift the keyboard and detach the ribbon cable with the spudger.
    • To disconnect the cable, disengage the locking tab of the ZIF connector with the spudger and pull the cable out gently.
  4. Dell Wyse Xn0m Mouse Sensor Board Replacement: adım 4, 1 resimden 1.
    • Remove the keyboard and set it aside. Detach the other ribbon cables with the spudger.
    • Remove five 8mm Phillips #1 screws.
  5. Dell Wyse Xn0m Mouse Sensor Board Replacement: adım 5, 1 resimden 1.
    • Pry open the laptop with the plastic opening tool.
  6. Dell Wyse Xn0m Mouse Sensor Board Replacement: adım 6, 2 resimden 1. Dell Wyse Xn0m Mouse Sensor Board Replacement: adım 6, 2 resimden 2.
    • Under the trackpad, detach the ribbon cables with the spudger.
    • Unscrew two 3mm Phillips #1 screws and lift the board from the pegs.
    • Remove the board from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jake Milligan
296 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 656
