Ana içeriğe geç
Dell XPS 10 Battery Replacement
Neye ihtiyacın var
  1. Dell XPS 10 Battery Replacement, Battery: adım 1, 3 resimden 1. Dell XPS 10 Battery Replacement, Battery: adım 1, 3 resimden 2. Dell XPS 10 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Slide one of the plastic opening tools in the crack on the side of the device with the windows button.
    • Slide the other plastic opening tool facing the opposite way in the crack next to the first one and pry the back cover off a little bit at a time or slide them around the edge as necessary.
    • Finally, slide the two plastic opening tools all around the case until it is open.
  2. Dell XPS 10 Battery Replacement: adım 2, 3 resimden 1. Dell XPS 10 Battery Replacement: adım 2, 3 resimden 2. Dell XPS 10 Battery Replacement: adım 2, 3 resimden 3.
    • Unscrew the three black, 4mm screws with a phillips screwdriver size PH 0 (one of which is under the gold colored ribbon cable.)
    • Unscrew the three gray, 3mm screws with the same screwdriver (phillips screwdriver size PH 0.)
    • Unplug the connector the connects the battery to the mother board.
    • Make sure to use a plastic opening tool instead of a metal spudger to avoid any unnecessary accidental shorting out of components.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
saraspam
244 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-1, Nance Fall 2016 USF Tampa, Team 2-1, Nance Fall 2016 üyesi
USFT-NANCE-F16S2G1
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 19
Her zaman: 3,125
