Ana içeriğe geç
Dell XPS 12 9250 Solid-State Drive Replacement
Neye ihtiyacın var
  1. Dell XPS 12 9250 Solid-State Drive Replacement, Removing the Back Cover: adım 1, 2 resimden 1. Dell XPS 12 9250 Solid-State Drive Replacement, Removing the Back Cover: adım 1, 2 resimden 2.
    • Turn the tablet over.
    • Remove the screws that secure the back-cover assembly to the display assembly.
    • Using a plastic scribe, pry up along the edges of the back-cover assembly.
    • Carefully, lift the back-cover assembly and turn it over.
  2. Dell XPS 12 9250 Solid-State Drive Replacement, Removing the Battery: adım 2, 1 resimden 1.
    • Remove the screws that secure the battery to the back-cover assembly.
    • Disconnect the battery cable from the system board.
    • Lift the battery, along with its cable, off the back-cover assembly.
  3. Dell XPS 12 9250 Solid-State Drive Replacement, Removing M.2 SSD: adım 3, 1 resimden 1.
    • Remove the screw that secures the solid-state drive to the back-cover assembly.
    • Lift and slide the solid-state drive off the back-cover assembly.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Johnathan Hammond
44.980 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.989 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 1,480
